Apex PowerFC
Old May 24, 2005 | 08:14 PM
  #26
rhettster's Avatar
Default Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">using the secondary 02 Sensor was what I was referring to. You can still use the secondary 02</TD></TR></TABLE>
Sweet, thanks for taking the time to answer that for me.
Old May 26, 2005 | 11:56 AM
  #27
Andre's Avatar
Default Re: Apex PowerFC (TURBO4drTypeR)
Let me know if the menus are understandable or if you would rename some items.
There are 2 settings that i don't understand yet, FC Datalogit calls them "Boost vs Ignition S.F." and "Inj vs Accel TPS".
There also some settings that even Power Excel Dealers can't view or set. Idle ignition control seems to be programmable and there are also some RPM and correction settings. Idle Air settings seems to be programmable too.
The whole communication / settings part is written entirely in ANSI C, that means it can be ported to nearly any hardware. The Pocket PC development environment is already installed
Old May 26, 2005 | 12:35 PM
  #28
TURBO4drTypeR's Avatar
Default Re: Apex PowerFC (Andre)
sweet! let us know when you'll be ready to release it... I would definately like to recieve a copy and donate(im not a cheap skate) i'll be glad to send you a good amount
Old May 26, 2005 | 01:44 PM
  #29
714phil's Avatar
Old May 28, 2005 | 08:58 AM
  #30
Andre's Avatar
Default Re: Apex PowerFC (STD ONEpointSIX)
Advance or Retard? https://honda-tech.com/zerothread?id=1259996
Old May 28, 2005 | 03:49 PM
  #31
blackzrd's Avatar
Power FC is the ****
Old May 28, 2005 | 08:30 PM
  #32
i have mine to start on retard
Old May 29, 2005 | 12:52 PM
  #33
Andre's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBO4drTypeR &raquo;</TD></TR><TR><TD CLASS="quote">i have mine to start on retard </TD></TR></TABLE>
Why do you want to retard the ignition under cold coolant conditions?
Base timing is 16 degrees BTDC. So if you retard 17 degress at 0C (32F) the ignition event will happen 1 degree AFTER TDC!
The idle must be shitty as hell, if the engine even runs.
Also why would Apexi split the settings into 2 tables if both are retard? Therefore and for the reasons above i bet it is advance till operating temperature (80C) is reached and then the second table is retard.
Old May 30, 2005 | 03:52 AM
  #34
Andre's Avatar
What features would you like to see in the FC Tune Box?
That's what i've yet:
- Gear based ignition
- Gear based injection
- 2 Step Rev Limiter
- Anti Lag
- Remote Boost Switch (Setting 1 / 2)
- Shift Light
- Fan Control
- EGT vs. ignition
- EGT vs. injection
- Input for wideband, can be used for auto tuning the fuel base maps
- Programmable inputs (ignition and injection correction)
- Programmable outputs
Reaction time is about 0.1 second.
What target price would be fair? The Datalogit costs $363, and that's not a fair price in my eyes.
Old May 30, 2005 | 08:35 AM
  #35
i just like to make sure there is a bit more fuel when i start the engine
btw your table of options are superb 200-250 a pop and you're a rich man!!!
Old Jun 4, 2005 | 05:22 PM
  #36
epic1si's Avatar
bump for an update
Old Jun 4, 2005 | 09:00 PM
  #37
Default Re: (epic1si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by epic1si &raquo;</TD></TR><TR><TD CLASS="quote">bump for an update</TD></TR></TABLE>
whats up man! haha
Old Jun 5, 2005 | 02:04 AM
  #38
vti444's Avatar
subscribing to thread for future reference
Old Jun 5, 2005 | 05:22 AM
  #39
turbotypeR@SPEC's Avatar
25 Year Member
i use one in my car.i made 560whp only because i ran out of injector(720cc).just put in 1000cc,maybe i can make some more.
as far as the fc goes,i think the biggest turn-off for people is the fact that the commander only give you a limited adjustability of the fuel map.they intend on you having a power accel dealer program the base map and you fine tune it yourself.they do this in hopes that it will keep you from blowing it up.you can,however change the base map if it is way off by adjusting the pim volt,a adjustment for boost,and one for rpm.you can have full map control with datalogit though.
as far as taking long to tune it goes,if done right,won't take long at all.i had the base map programed by xs engineering(i sent the m a list of mods on a fax and they tuned it for $150 when i bought it) and then i spent 2 hours on the dyno and it was perfect.it ran fine before the dyno,we spent the time on it because i wanted more power.i use the gm 3 bar map sensor as well.it works great.i have used the fc on hondas and nissans and love them.the thing i like most is it runs like stock.mine idles and runs just as good as stock with the 1000cc injectors!
Modified by turbotypeR at 9:40 PM 6/5/2005
Old Jun 5, 2005 | 10:48 AM
  #40
Default Re: Apex PowerFC (turbotypeR)
WoW! so you are running on 1000ccs and it idles fine? mine ran fine but it idled like **** btw you're the only person i know of that is making that much power on the powerafc on a b series
Old Jun 5, 2005 | 11:07 AM
  #41
a1320addict's Avatar
got a brand new one for saleee...pm me if you want it!
Old Jun 5, 2005 | 06:38 PM
  #42
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBO4drTypeR &raquo;</TD></TR><TR><TD CLASS="quote">WoW! so you are running on 1000ccs and it idles fine? mine ran fine but it idled like **** btw you're the only person i know of that is making that much power on the powerafc on a b series </TD></TR></TABLE>
thanks for all the flowers! did you adjust your injector lag time? mine idled fine (i did have to lower the lag time)right of the bat,but i was already using 720cc.when i first started using it with the 720's,i had to make big changes in the lag time.
Old Jun 5, 2005 | 07:14 PM
  #43
maybe my tuner was tryin to rape me??? thanks for the info though... helped out a bunch... it must be nice that you have a dyno #. all i got was a partial tune and that was it i made over 340whp and 297torque at a 5.5k rpm dyno cutoff at 12 psi..... i only had just enough to beat an 05 stock viper from behind after i got off the dyno and revved to 9k, that was it.... ever since then i've had no support and been untuned...
Old Jun 6, 2005 | 05:14 AM
  #44
Andre's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBO4drTypeR &raquo;</TD></TR><TR><TD CLASS="quote">btw you're the only person i know of that is making that much power on the powerafc on a b series </TD></TR></TABLE>
I think the most power overall with a PFC makes a Nissan Skyline in Japan with about 800 HP.
The Civic with the PeakBoost kit in the DSport made 402whp with a PFC.
Old Jun 6, 2005 | 06:24 AM
  #45
Oyvind Ryeng's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andre &raquo;</TD></TR><TR><TD CLASS="quote">
The whole communication / settings part is written entirely in ANSI C, that means it can be ported to nearly any hardware. The Pocket PC development environment is already installed </TD></TR></TABLE>
Are you saying it's possible to tune the car by the means of a PDA?
Old Jun 6, 2005 | 07:08 AM
  #46
Andre's Avatar
Default Re: Apex PowerFC (Oyvind Ryeng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oyvind Ryeng &raquo;</TD></TR><TR><TD CLASS="quote">
Are you saying it's possible to tune the car by the means of a PDA?</TD></TR></TABLE>
FC Tune is portable to Windows CE and derivates. For all other operating systems only monitoring/logging will be available. I don't want to rewrite the whole user interface.
I will also make some additional hardware for the PFC but i don't want to tell too much yet.
I'll email a preview to some users here at the end of this or next week.
Old Jun 6, 2005 | 11:28 AM
  #47
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andre &raquo;</TD></TR><TR><TD CLASS="quote">FC Tune is portable to Windows CE and derivates. For all other operating systems only monitoring/logging will be available.</TD></TR></TABLE>
Jesus Christ. This completely blows my mind, I had no idea we, the human race, were "there" yet; I love technology. This has just closed the casket with Uberdata/Hondata/Turboedit/Chrome/Neptune/Haltech/Autronic/FAST/Microtech dead and stiff inside. At least for me personally, as a PDA-geek of astronomic proportions. I am willing to accept a possibly "less" of a tune for PDA controllability (I just assume that the PowerFC will not want to run DIS/Coil-On-Plug).
Edit:
I definately need more information. How to hook up the PDA (I have USB-host-functionality, by the way.) to the car/ECU/PowerFC? Wireless 802.11b by any chance? And what ECU will one have to lay down as the corner stone (did I hear JDM ITR or CTR, or is this my misconception?)?
Old Jun 6, 2005 | 01:55 PM
  #48
onefstek's Avatar
Im using the PFC and making 496whp and 325wtq on 92 octane pump gas at 17-20 psi boost.
Old Jun 10, 2005 | 11:21 AM
  #49
epic1si's Avatar
any update or news?
Old Jun 10, 2005 | 02:47 PM
  #50
read ****! he's almost done...
