Apexi Turbo Timer 02 sensor wiring
Old Nov 4, 2006 | 09:33 AM
LowTEC-Derbo's Avatar
Default Apexi Turbo Timer 02 sensor wiring
I just recently got an Apexi turbo timer installed.
The turbo timer works and all but the 02 sensor reading is off.
The reading seems to go from anywhere from 4.30 (cold) to 1.15 (when warm) It doesnt make any sense to me. It is suppose to read somewhere between 0v and 1.0v not anything above..Anyways, the A/F LED will flash red/green and have "----" on the screen.
This is obd1, and it has been grounded to the ecu as well as the white wire to the o2 sensor wire. I followed APEXi's instructions and now I'm stuck. any ideas? Which one is the correct o2 sensor? I based it as the 5th wire (white) on the rear most harness clip (closest one to you when you unplugg ecu)
Modified by crazyxzer0 at 11:27 AM 11/4/2006
Old Nov 4, 2006 | 12:33 PM
Default Re: Apexi Turbo Timer 02 sensor wiring (crazyxzer0)
Old Nov 4, 2006 | 04:44 PM
bizzump!!
Old Nov 4, 2006 | 07:43 PM
ImPuLsIvE
Oct 9, 2007 09:53 AM
LowTEC-Derbo
Nov 6, 2006 05:25 PM
D15Bbigred
Mar 2, 2006 09:39 AM
cam0693
Oct 14, 2002 05:56 PM
