Anyone using this turbo (Turbonetics)
Old Nov 18, 2008 | 02:59 PM
ys1civicsi's Avatar
Icon6 Anyone using this turbo (Turbonetics)
I recently bought this turbo from a friend not really knowing much about it and do not know to many specs on it other than its a t3/t4. I believe it is a 57 trim but not positive, due to it being at home and i am at school so i can not measure the a/r. I believe it is a 57 trim .63 a/r Let me know your results and what type of power you are making with this turbo. thanks guys.
Note this is not the exact photo of my turbo but identical, so if original owner wants me to take down will do so thanks.
Old Nov 18, 2008 | 07:56 PM
DOHC_16v's Avatar
I'm running either the same or very similar turbo on my 2L 16v VW motor. It's an older Turbonetics(pre 02-03 I think judging by the comp housing). The hotside specs should be on the housing below the WG port if it's a 5 bolt housing.
You should be able to make 400-450whp out of it, depending on the turbine wheel. The're good turbos, and some of them had a ball bearing CHRA option(Ballistic series)
This site has more info on the older Turbonetics:
http://64.225.76.178/main.htm
Old Nov 19, 2008 | 06:57 AM
ys1civicsi's Avatar
hey thanks a lot, I figured it was an older turbo but wanted to see what I could do with it. i got it relatively cheap. anyone else out there running a similar turbo and also is there a way to tell if its ball bearing without taking it apart?
Old Nov 19, 2008 | 06:58 AM
spoolie's Avatar
wow...you ask a question about a turbo...put up no information on it other than the name brand...and put up the wrong picture...
fail
Old Nov 19, 2008 | 08:00 AM
TheShodan's Avatar
Moderator
[QUOTE=DOHC_16v;36444768The're good turbos, and some of them had a ball bearing CHRA option(Ballistic series)
[/QUOTE]
Actually, that looks like one of the older v1-trim models that were used from Turbonetics, good to about 400whp max. Also, Turbonetics uses CERAMIC ball-bearing CHRAs, not the same as the Ballistic series. I never like them because in previous years, the bearings used to literally disintegrate with shock.
Old Nov 19, 2008 | 08:32 AM
HiProfile's Avatar
Originally Posted by TheShodan
Actually, that looks like one of the older v-trim models that were used from Turbonetics, good to about 400whp max. Also, Turbonetics uses CERAMIC ball-bearing CHRAs, not the same as the Ballistic series
Ditto on it being T04B compressor wheel. T04E wheels are all 6-blade now, really old T04B's are 8-blade, newer are 7-blade. More than likely its a stg3 turbine. A stg5's size makes it very obvious.
The only bearing used in those turbos were ceramic & bronze journal bearings. The only non-GT Garrett turbos with ball bearings are very new (with the option) or were converted. The only difference is very slightly faster transient response time; they don't spool faster.
On a decent motor with pump gas, 400whp is about what you'll see. 500whp MAYBE with C16 and a highly modded engine.
Old Nov 19, 2008 | 07:08 PM
ys1civicsi's Avatar
cool thanks guys
Old Nov 20, 2008 | 03:35 PM
ys1civicsi's Avatar
bump TTT
Old Nov 21, 2008 | 05:10 PM
TheShodan's Avatar
Moderator
what is there to bump? Your question has been addressed.
NosCivic01
May 25, 2006 12:01 PM
jdm'dc2sc61
Jul 7, 2005 04:51 PM
carsaregood
Jan 8, 2004 04:40 PM
oday
Jul 20, 2003 05:13 AM
ZCREX
Jan 30, 2002 01:46 PM
