anyone using a inline booster electric Water Pump?
Old Sep 22, 2013 | 07:02 AM
2ltrgsr's Avatar
Default anyone using a inline booster electric Water Pump?
With my coolant temp setting in the low 200's and sometimes around 215 at idle, i was looking into the option of running one of these:
http://www.stewartcomponents.net/Mer...Code=ElectPump
I have a all-in-fab style radiator setup with it being tucked and setting at lower point then stock obviously..... maybe im working against my self on this one
Any thoughts?
Old Sep 22, 2013 | 07:40 AM
Turbo-LS's Avatar
Default Re: anyone using a inline booster electric Water Pump?
Coating or wrapping that beautiful manifold would drastically improve your cooling capabilities. That baby is heat soaking your radiator for sure. What fan are you running?
Old Sep 22, 2013 | 09:37 AM
redboost10's Avatar
To be honest, the all-in fan shroud is horrible. That shop is local and we have reworked more than a handful of those radiator setups.
Is that a tube header?
Old Sep 22, 2013 | 09:44 AM
Turbo-LS's Avatar
I am personally running a VW scirocco aftermarket dual pass radiator in my DC tucked in the rad support and it works very well. Idk much about the all in unit though. Is your rad fill point high enough to bleed the engine properly of air? I still feel heat soak is one of your biggest issues with that manifold creating a whole lot of heat
Old Sep 22, 2013 | 12:26 PM
2ltrgsr's Avatar
well i've had to bleed the unit twice... its a atco core that a local shop(Rameybuilt) put together, i had issues with it pushing coolant.... Then i used a funnel and got the water level higher then the engine and it pushed the air pockets out
its burn stainless collector that rameybuilt(Brian ***) put together
Old Sep 22, 2013 | 12:45 PM
Turbo-LS's Avatar
I would invest in a custom coolant neck fill bottle. Contact Tim at Turbo Elements he can make one for you. This will help you bleed the system. You could def be air bound to some extent
Old Sep 23, 2013 | 04:20 AM
2ltrgsr's Avatar
yeah before i went in for the night, i put the laptop on and saw temps reach 242f... so i shut it down and tried to bleed the system
hopefully the water pump is just the culprit and not a blown headgasket
Old Sep 28, 2013 | 06:00 AM
2ltrgsr's Avatar
well i elevated the front end quite a bit yesterday and used a funnel on the water neck and let the idle sit awhile and the level rose and bubbled...
I drop the car down and let it cool, turned it back on and now its running fine... doesn't go above 203f at a stoplight or a long idle period
Old Oct 4, 2013 | 03:46 AM
2ltrgsr's Avatar
UPDATE: yesterday i took the car out and noticed that by time i got to the first stoplight my temp gauge was over the half way mark... I pull over and pop the hood noticing that the bottom hose is cool like before
Could there still be a air pocket?
Old Oct 4, 2013 | 04:22 AM
Turbo-LS's Avatar
You've either got a very airbound system because of the low coolant till point or a blown hg pushing air into the system giving you false overheating conditions.
Leak down test should rule out HG. If it's not headgasket you'll need to come up with another fill point.
Old Oct 4, 2013 | 04:39 AM
2ltrgsr's Avatar
im thinking i have a stubborn air pocket.... hopefully
i bought this to test and remove the potential air pocket
UView (UV 550500) AirLift II Economy Refiller - Amazon.com UView (UV 550500) AirLift II Economy Refiller - Amazon.com
Old Oct 4, 2013 | 02:04 PM
MRGRIM's Avatar
R.I.P. Mark
have you checkedd the thermostate
does the fan turn on at temp
is the water pump working
Old Oct 5, 2013 | 12:36 PM
2ltrgsr's Avatar
took thermostat out to get some flow.... not so much
Update:
This morning i used a combustion chemical test and the chemical stayed blue and did not turn yellow what so ever .... which would indicate a oil leak in the coolant system.
Waiting on my air pressure coolant refiller to get here, maybe that will get whatever air pocket out thats in the system
Ty h2b eg
Jan 7, 2018 12:23 PM
crxhybrid1320
Jul 1, 2011 06:01 PM
SweetDA9_TR
22
May 22, 2009 08:06 AM
bigslimdog
Aug 10, 2004 03:37 PM
dbman96
Aug 8, 2001 02:24 PM
