anyone lean out in deaceleration?
i noticed when i push in the clutch and let off the gas my car goes lean for a second and then goes back to normal, will this hurt my car? should i even worry about it? i notice it also happens when i am cruising and traffic starts to slow down i let off the gas and it goes lean anyone deal with this?
Re: anyone lean out in deaceleration? (Btothe3rdDegree)
When your TPS = 0 (let off gas), the injectors cut off until the engine drops below 1100 rpms and then proceeds to idle.
This is normal.
This is normal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Btothe3rdDegree »</TD></TR><TR><TD CLASS="quote">cool so it wont do any damage?</TD></TR></TABLE>no load no damage
Re: anyone lean out in deaceleration? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">If you drove around with 12:1 AFR all the time youd get 5mpg.</TD></TR></TABLE>
if my idle AFR is around 12:1 would first gear be pretty bogged down? the reason i ask is cuz it is!
if my idle AFR is around 12:1 would first gear be pretty bogged down? the reason i ask is cuz it is! </TD></TR></TABLE> Its not good.
Re: anyone lean out in deaceleration? (turbozxi)
Thats way to rich at idle. You want to be around 14.5-15.0(relatively lean) during idle conditions. Timing can also effect idle quality but if your that rich I would try leaning it out for 1. To save gas and 2. To get a better idle.
This is a good question! I was wondering this as well, but I see that I'm not the only one with this issue. As for it not hurting the motor, what you all said, that is what I thought. But now that I know what others think about it, it makes it a little easier to swallow. Cool.
Hey, I got something to throw in, just food for thought. I had my car tuned with the stock civic EX o2 sensor, and it ran fine. I had an accident at the track, and, long story short, had to get a new O2 sensor. So, I got a hold of an integra LS sensor, and now my A/F gauges are all different. They still read "normal", but they um.... "dance" alot different now. Anyway, just wanted to throw that out there.
JDM_Frijoles
03-24-2007 07:23 AM
