anyone know the part number for the plug on the GM boost control???
Have you try the AEM forum....? well you probably have but if you ask one of thsoe guys you'll probably going to get the answer faster than here... oh I got a question... where you get the vacum line that go from the wastegate to the boost solenoid..? if you have them allready....
Pigtail for the MAP sensor--
Conduct-Tite P/N: 85115, $9.99
Labelled specifically for a GM MAP sensor.
Pigtail for boost solenoid--
Conduct-Tite P/N: 85145 (forgot the price but not that much)
Labelled for a "A/C compressor clutch socket"
You will have to slot the MAP sensor pigtail though. As other users have said, a Dremel or a Rotozip might make the job easier. I used a sharp utility knife, and that worked just fine for me.
The pigtail for the boost solenoid is just a plug & play affair--no slotting needed.
Vacuum line: NAPA autoparts. OEM Honda-type vac lines.
92redhatch
Aug 11, 2012 12:55 PM
street_ride14
Jun 4, 2010 01:10 PM
eg:R
Oct 23, 2005 01:54 PM
Boostless97Lude
Feb 12, 2003 12:46 PM
