anyone know the colors for the ignition harness?
i decided to install my tt and i have the haynes book but it doesnt tell you the colors of the wires, i just wanted to know if any of you guys knew the colors of:
1.ACC
2.ON
3.START
1.ACC
2.ON
3.START
Hmmm...
...kind of car would help for starts.
My TT was listed as POWER, IG1, and IG2. Power was solid white, IG1 was Black/Yellow, and IG2 was White/Black.
That is for generic Honda (i.e. Civic/delSol/Teg). Your colors may be different.
- Slater
- Slater
OK then...
...93 Civic will have the same colors I listed. Those are what you want to use.
Note that if you have an alarm you will have to bypass it with a relay to make the TT work with the alarm.
Good luck,
- Slater
Good luck,
- Slater
Re: Hmmm... (Slater)
OK so 12v constant would be white
ACC would be black/yellow
ignition would be white black
is this correct?
is this correct?
