Element alarm
Old Feb 12, 2003 | 07:28 AM
yoshi234's Avatar
I shoot brides
25 Year Member
Default Element alarm
I want to put an alarm into an Element, but I can't find a wiring diagram for it online. Anybody have it or can point to a link that has it?
thanx
Old Feb 12, 2003 | 07:36 AM
99_BlackSI's Avatar
Default Re: Element alarm (yoshi234)
ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white |+ |ignition harness |
| STARTER|black/white |+ |ignition harness |
| IGNITION|black/yellow |+ |ignition harness |
| ACCESSORY|black/red |+ |ignition harness |
| SECOND ACCESSORY|white/red |+ |ignition harness |
| POWER LOCK|white/blue |- |gray plug above drivers kick|
| POWER UNLOCK|white/green |- |gray plug above drivers kick|
| LOCK MOTOR|yellow/black | |driver kick panel |
| UNLOCK MOTOR|yellow/green | |driver kick panel |
| DISARM DEFEAT|yellow | |passenger kick panel |
| PARKING LIGHTS +|red/black | |driver kick panel |
| PARKING LIGHTS -|blue | |factory alarm plug *1 |
| HEADLIGHTS|blue/red |- |factory alarm plug *1 |
| DOOR TRIGGER|*2 |- |factory alarm plug *1 |
| DOME SUPERVISION|comes on with unlock| | |
| TRUNK/HATCH PIN|red |- |factory alarm plug *1 |
| HOOD PIN|yellow/red |- |factory alarm plug *1 |
|TRNK/HTCH RELEASE|black/yellow |- |driver kick panel |
| FCTRY ALARM ARM| | | |
|FCTRY ALRM DISARM| | | |
| DISARM NO UNLOCK| | | |
| TACHOMETER|blue | |test connector *3 |
| SPEED SENSE|blue/white | |cruise control module *4 |
| BRAKE WIRE|white/black |+ |brake pedal switch |
| HORN TRIGGER|orange |- |steering column |
| WIPERS|blue (L), blu/yel(H)|- |steering column |
| LF WINDOW UP/DN|red/blk - red/yel |A |driver window switch |
| RF WINDOW UP/DN|blu/red - blu/wht |A |driver kick panel |
| LR WINDOW UP/DN|blu/blk - brown |A |driver kick panel |
| RR WINDOW UP/DN|blu/org - blu/yel |A |driver kick panel |
| SUN RF OPN/CLOSE|grn/yel - grn/blk |A |relays above driver kick |
| RADIO 12V|white/red |+ |radio |
| RADIO GROUND|black |+ |radio |
| RADIO SWITCH|yellow/red |+ |radio |
| RADIO ILLUMINATE|red/black |+ |radio |
| LF SPEAKER|grn/blk - lt green | |radio |
| RF SPEAKER|grn/yel - gry/red | |radio |
| LR SPEAKER|blu/wht - blu/blk | |radio |
| RR SPEAKER|pink - blu/yel | |radio |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555U. *1 The factory alarm plug is a green plug to the left of the steering column. *2 The drivers door trigger is green, and the passenger door trigger is lt. green/black. Use both and diode isolate each. *3 The test connector is next to the battery. *4 The cruise control module is to the left of the steering column.
That is directly from DEI
Dave
Old Feb 12, 2003 | 08:29 AM
yoshi234's Avatar
I shoot brides
25 Year Member
Default Re: Element alarm (99_BlackSI)
thanks Dave
slikz714
Jul 21, 2007 03:27 PM
b16 matt
Audio / Security / Video
Dec 19, 2005 05:13 AM
njandrewg
Mar 9, 2005 12:22 PM
InTeGrA B18b1
Dec 30, 2003 03:36 PM
ITSFEROZ
Nov 4, 2002 01:22 PM
