anyone here using uberdata and have datalogging at the same time?
Old May 12, 2004 | 03:43 PM
tvrsir's Avatar
Default anyone here using uberdata and have datalogging at the same time?
what did you use to hook up to datalog. is ecu control compatible with uberdata?
Old May 12, 2004 | 03:49 PM
1316130057's Avatar
Default Re: anyone here using uberdata and have datalogging at the same time? (tvrsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">what did you use to hook up to datalog</TD></TR></TABLE>
A Wide Band O2 Sensor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">is ecu control compatible with uberdata</TD></TR></TABLE>
If you mean "is modification of the original ECU's maps and/or functions possible with Uberdata" then the answer is "hell yes".
Old May 12, 2004 | 04:19 PM
ndogg's Avatar
uberdata now has dataloggin built in. no need for ecu control anymore. you still need to mod the ecu just like with ecu control to hook your laptop up.
Old May 12, 2004 | 04:57 PM
b18cls1's Avatar
Default Re: anyone here using uberdata and have datalogging at the same time? (ndogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">uberdata now has dataloggin built in. no need for ecu control anymore. you still need to mod the ecu just like with ecu control to hook your laptop up.</TD></TR></TABLE>
yes you still have to add a usb or serial port in the ecu and now you can datalogg with uberdata
Old May 12, 2004 | 06:18 PM
tvrsir's Avatar
Default Re: anyone here using uberdata and have datalogging at the same time? (b18cls1)
okay thanks for the help guys
Old Jul 7, 2004 | 06:25 AM
JOeS's Avatar
I'm not sure and couldn't find the info:
Do I need a wideband with datalogging, like the PLX M400/M500, for the air/fuel data or can I use a wideband without datalogging, like the PLX M300, and use Uberdata to log the data, including air/fuel?
Old Jul 7, 2004 | 07:13 AM
Overblown-Teg's Avatar
Default Re: anyone here using uberdata and have datalogging at the same time? (JOeS)
Have you gone to the Uberdata forum??
You need a wide band if you plan to datalog AFR. You can use pretty much anyone you want. Read the Uberdata forum Please..
Old Jul 7, 2004 | 07:27 AM
mrbsponge's Avatar
what i am searching for is if the program can be modded without burning a new chip?
or is it just controled on the main screen of the laptop
Old Jul 7, 2004 | 07:42 AM
Default Re: (mrbsponge)
nope you still have to burn a chip.. its not rtp yet.
Old Jul 7, 2004 | 08:12 AM
JOeS's Avatar
Default Re: (Overblown-Teg)
You can with ROMulator, right? But, I might be confused with TurboEdit.
Old Jul 7, 2004 | 08:22 AM
Default Re: (JOeS)
I believe you can with that.
Old Jul 10, 2004 | 01:26 AM
leed's Avatar
Default Re: (JOeS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOeS &raquo;</TD></TR><TR><TD CLASS="quote">You can with ROMulator, right? But, I might be confused with TurboEdit.</TD></TR></TABLE>
Yes, Romulator works fine.
And despite what might be suggested on their site (or Hondata's for that matter), you can do real time updates with the engine running.
OMG WTF
Feb 22, 2006 09:02 AM
swtch7
Jul 31, 2005 08:08 AM
93civciv
Apr 7, 2005 07:40 AM
H8 O ATE
Jan 9, 2005 06:27 PM
