Is anyone hear boosting an ls/vtec?
I will boosting an ls/vtec soon and I just wanna hear some feedback basically of any other owners, or if you know anyone...it WILL be built right with z10 girdle kit etc.....resleeved...all the goodies, anything I should keep in mind when doing this swap?
check out http://www.teamultraspeed.com
VA section. alot of guys there w/ LS/vtec turbo hatches
u may get some insight there
I have one and I think there's at least one other HT member as well. It's no drama. Where do you plan on pulling oil for the turbo? I'm sourcing from the head near the dist. No probs yet.
If you plan on using the z10 adapter oil pump adapter, do it will the engine is out because there is barely enough room between the oil pump and the alternator. You might even need to buy a longer belt. I bought the adapter and decided not to use it cause I'd have pull the alternator and am tired of being uncer the car.
HTH
HTH
