anyone have problems with their eagle crank like this
Old Feb 21, 2007 | 08:40 PM
AllmotorEH2's Avatar
Default anyone have problems with their eagle crank like this
ok so heres the issue i am having and i would like too know if anyone else running the eagle cranks have had this problem..... So i checked all clearances on all my bearings and everything was looking great. I was installing the crank and when i went too put the thrust bearings in one of them was way too tight. I couldnt even get it too slide in. i tried everything i could to get it in without damaging anything. I have built several motors and have never had this problem however this is my first build with a aftermarket crank.... I am using all honda bearings ect... I am going to drop the block,crank, and bearings off at my machine shop this weekend to have them take a look at it and if the crank checks out fine then can they take a thousands or soo off the thrust bearing or would that need to come off the crank? Anyways any help would be appreciated or anyone with any experiences similar it would be great too hear your input.... any help or suggestions would greatly be appreciated.
Thank You ,
Joel
Old Feb 22, 2007 | 05:05 AM
maddog20's Avatar
Default Re: anyone have problems with their eagle crank like this (AllmotorEH2)
you need to PM ninesecrx on here.
Old Feb 22, 2007 | 07:00 PM
thanks man
Old Dec 28, 2009 | 11:04 AM
n/a boost killa's Avatar
I also am having this problem with the eagle 95mm crank. Mains are fine but thrust bearings are real tight. Help please?
Old Dec 28, 2009 | 12:05 PM
Vagitarian's Avatar
They sell various sized thrust bearings, there should be no resistance
Old Dec 28, 2009 | 12:35 PM
boostedcivicsir's Avatar
Mr. Badwrench
more importantly, there is a crank shaft end play spec, i don thave it on fron tof me though.
gdrum
Apr 6, 2017 06:57 AM
2000BoostedEX
Aug 10, 2008 07:18 PM
AllmotorEH2
Feb 23, 2007 04:40 PM
NetLogic
Dec 16, 2004 01:57 PM
