anyone else having this problem
Old Mar 5, 2006 | 05:09 PM
mrrugsr's Avatar
Default anyone else having this problem
anyone else having this problem? B18C1 with a blox manifold and a tial 38mm WG. WONT FIT. i moved the dip stick and it still wont fit. bumps the motor. id rather not elbow out, i wanna keep the WG on top. what to do?
Old Mar 5, 2006 | 06:02 PM
Quad-Damage's Avatar
Default Re: anyone else having this problem (mrrugsr)
bend the dipstick and it will fit, also u might have to shave the v cover just to clear the waste gate or get a elbow
Old Mar 5, 2006 | 08:55 PM
BrokeAssWhiteboy's Avatar
my house has wheels on it
Default Re: anyone else having this problem (Quad-Damage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damage &raquo;</TD></TR><TR><TD CLASS="quote">bend the dipstick and it will fit, also u might have to shave the v cover just to clear the waste gate or get a elbow</TD></TR></TABLE>did you even read his post????
do yo uthink flattening one side of the "hat" would help you any, i know that the flange is kinda thick around the o.d. and you could probably remove some material there
Old Mar 6, 2006 | 12:23 AM
project dc2's Avatar
Default Re: anyone else having this problem (BrokeAssWhiteboy)
already done it before. the blox manifold will hold boost like a rock however it was always built to use a WG elbow.
you can grind some off the valve cover and hte head. just do enough to fit dont go too crazy
Old Mar 6, 2006 | 05:08 AM
tepid1's Avatar
Default Re: anyone else having this problem (project dc2)
That is what you get for buying a Blox manifold....
Old Mar 6, 2006 | 05:21 AM
nsxmatt's Avatar
Default Re: anyone else having this problem (tepid1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 &raquo;</TD></TR><TR><TD CLASS="quote">That is what you get for buying a Blox manifold....</TD></TR></TABLE>
Not everyone can afford a $1000 manifold. Unless you have something worth saying just don't reply, that comment was useless.
Old Mar 7, 2006 | 10:15 AM
Tactic$'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">however it was always built to use a WG elbow.
really? I thought this was a "discovery" shortly after the first one's were shipped??
Kind of a "oh ****, didn't think about that" issue.
Old Mar 7, 2006 | 10:36 AM
turboH22Aakkord's Avatar
Default Re: anyone else having this problem (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">
Not everyone can afford a $1000 manifold. Unless you have something worth saying just don't reply, that comment was useless.</TD></TR></TABLE>
agreed... and god bless HT!
Old Mar 7, 2006 | 10:55 AM
theo99gsr's Avatar
Default Re: anyone else having this problem (turboH22Aakkord)
I have that manifold and ran into the same problem. If you dont want to use an elbow your going to have to do some grinding. I had spoolin performance make me a custom setup with an elbow. Talk to project dc2.
Old Mar 7, 2006 | 11:23 AM
GS-R Civic's Avatar
Default Re: anyone else having this problem (theo99gsr)
I heard about that problem before I installed my set up. I even bought a turbosmart wastegate which was suppose to be a little shorter and still fit, but it didn't. I just get the elbow, I'd rather do that than shave the valve cover.
You can get one here for $35:
http://www.importparts.com/sho...=5365
I had mine made up by Project DC2 with a dump tube and it works fine! (little more expensive though)
Mine Blox manifold and elbow set up hold 7psi all the time, never a problem!
Old Mar 7, 2006 | 02:56 PM
b18ccivics's Avatar
even if you did make it fit i dont think the hood will shut, i may be wrong but i dont have much hood clearance there
Old Mar 7, 2006 | 04:15 PM
nY's FiNeSt's Avatar
Default Re: anyone else having this problem (b18ccivics)
easiest solution....get rid of it for an inline pro mani
Old Mar 7, 2006 | 04:35 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: anyone else having this problem (nY's FiNeSt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nY’s FiNeSt &raquo;</TD></TR><TR><TD CLASS="quote">easiest solution....get rid of it for an inline pro mani</TD></TR></TABLE>
and its not $1000 either.
Old Mar 7, 2006 | 04:53 PM
Adi Radoncic's Avatar
On Fire!
Default Re: anyone else having this problem (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">
and its not $1000 either. </TD></TR></TABLE>
Inline pro for life!
Old Mar 7, 2006 | 10:50 PM
Default Re: anyone else having this problem (Tactic$)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tactic$ &raquo;</TD></TR><TR><TD CLASS="quote">
Kind of a "oh ****, didn't think about that" issue. </TD></TR></TABLE>
i guess that would be my fault, i fitted it up on an LS motor and it fit perfect, I didnt account for VTEC heads. Upon explaining to blox, they stated they never meant to have it bolt up, it was always supposed to be used with the WG elbow.
i will be producing a bolt up downpipe for them soon and wg elbow to be mass produced for their manifolds. keep on a look out
Old Mar 8, 2006 | 07:51 AM
rudebwoy's Avatar
had the same problem, shaved the head and valve cover about a 1/8" to 1/4" and also the webbing on your block for it to fit, and bend the dipstick. pic of mine with a spoolin downpipe
click on the pic you will see how much I had to shave
Modified by rudebwoy at 10:18 PM 3/11/2006
Old Mar 8, 2006 | 11:58 AM
GS-R Civic's Avatar
Default Re: (rudebwoy)
Just get the elbow and your problem is solved:
Old Mar 8, 2006 | 12:08 PM
Default Re: (GS-R Civic)
SPoolin = #1 blox turbo products dealer
Old Mar 8, 2006 | 02:02 PM
nitrofish420's Avatar
Default Re: (project dc2)
You could probably angle mill the flange of the WG to tilt it foreward slightly.
Old Mar 8, 2006 | 02:59 PM
Weq's Avatar
Weq
im just guessing here, but what about grabbing another tial flange and use it to space the gate up?
Old Mar 8, 2006 | 04:42 PM
nsxmatt's Avatar
Default Re: (Weq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Weq &raquo;</TD></TR><TR><TD CLASS="quote">im just guessing here, but what about grabbing another tial flange and use it to space the gate up?</TD></TR></TABLE>
It would hit the hood.
Old Mar 8, 2006 | 04:58 PM
mike1114's Avatar
Default Re: (nsxmatt)
in the end, I had to go with the 90 degree elbow also. There is no other way around it really.
Old Mar 9, 2006 | 11:50 AM
rudebwoy's Avatar
and the good thing about it I have a brand new elbow here that I bought from import parts for $35+ shipping, but you can have it for $35 shipped.
in my opinion it works and look better without the elbow, I like the way it looks with the wastegate on top. problem is when the engine is hot its a bitch to check your oil, and if you dont rotate the wastegate like I did in the pic you will burn up the vac line. blox is a nice manifold, but it takes a lot to make it work
Old Mar 10, 2006 | 11:51 PM
mrrugsr's Avatar
i agree, i like the look of the WG on top.
Old Mar 10, 2006 | 11:56 PM
mrrugsr's Avatar
also YES i would like an inline pro mani BUT i already have this one and dont feel like buying another(unless its a great deal) and then trying to sell this BLOX mani
