Any way to lower compression without changing pistons?
Old Nov 12, 2002 | 10:02 PM
StinkyTofu's Avatar
Default Any way to lower compression without changing pistons?
My motor right now is built for n/a.
[Modified by StinkyTofu, 9:36 AM 3/15/2003]
Old Nov 12, 2002 | 10:05 PM
I Like Boost's Avatar
Default Re: Any way to lower compression without changing pistons? (StinkyTofu)
ya they have a few thick headgaskets on the market, just look around. what was your c/r around 11.0:1?
Old Nov 12, 2002 | 10:21 PM
StinkyTofu's Avatar
Default Re: Any way to lower compression without changing pistons? (BEe18SeAONe)
With a stock OEM 3 piece gasket, the compression is around 11.36:01
Old Nov 13, 2002 | 12:52 AM
Tofurky's Avatar
give inlinepro a call, they have some nice ones
Old Nov 13, 2002 | 01:00 AM
blufke's Avatar
Default Re: Any way to lower compression without changing pistons? (Ruckus138)
well how about this:
CR= 9.576293094958858:1 with a 0.098" thick headgasket
10.027323530871673:1 with a 0.078" thick headgasket
both thicknesses happen to be available from 2K_TEG for 126 for .078 and 181 for .098 and you could also go to:
9.129503013393615:1 with a 0.12" one for 181 as well. id go 9.6 or 10 though. keep good power at low boost.
Old Nov 13, 2002 | 04:34 AM
lazyguy's Avatar
if u really want ill switch my stock block(gsr) with u for urs, we can work something out let me know if ur interested
thanks
Old Nov 13, 2002 | 02:41 PM
StinkyTofu's Avatar
Default Re: Any way to lower compression without changing pistons? (lazyguy)
oh wow, thanks alot. That definitely helped me out. Would that be a smart choice for me to do though? Wouldn't having a really thick head gasket advance my timing?
Lazyguy-sorry man, i'm keeping my block heh.
Old Nov 13, 2002 | 02:51 PM
blufke's Avatar
i dont see why it would advance your timing. i would go with the 10:1 and still make nice power. im considering upping my CR in my LS.
Old Nov 13, 2002 | 04:00 PM
Fatty_1775's Avatar
Default Re: Any way to lower compression without changing pistons? (blufke)
How about for a B16? Anyone have info for head gaskets thqt can lower my compression. I am running a stage 2 revhard on a b16 with stock internals.
Old Nov 13, 2002 | 04:16 PM
blufke's Avatar
Default Re: Any way to lower compression without changing pistons? (import_racer)
jdm or usdm?
here is the link for the cometic GB:
https://honda-tech.com/zerothread?id=252504
get the .054" for 81 shipped and you will be at 9.55:1 usdm or 9.72:1 jdm. thats i nice CR to be at.
Old Nov 13, 2002 | 04:21 PM
StinkyTofu's Avatar
Oh, i was thinking that it would advance my cam timing because the height of the head would be slightly off. They say when you mill the head, you retard the cam timing slightly because the total height of the head is smaller, and so the timing belt would be slightly off.
Old Nov 14, 2002 | 09:21 AM
Fatty_1775's Avatar
second gen jdm
b00stedOne
Jul 28, 2014 09:56 AM
lsjon
Jun 18, 2009 12:25 PM
frmdstryr
Apr 30, 2009 02:57 AM
FyReo3
Jun 5, 2003 11:18 PM
madman604
Jun 2, 2003 11:09 AM
