Any one use skunk 2 turbo cams?
I Think I'm TOO White For This Thread
Re: (Gomez_Si)
midnight bump well im gonna go out and get ed tonight. so i guess ill check back on this thread when i come out of my coma.
Modified by gsrpwr2004 at 11:24 PM 10/8/2004
Re: (gsrpwr2004)
this is my last desperate attempt to get an answer besides "no because they cost too much". PLEASE HELP!!!!!!
Re: (gsrpwr2004)
I have never tried the Skunk2 turbo cams, however I have used the Crane cams turbo roller cam with the ferrea roller folowers. There is a huge difference from the JDM GSR cams. Idle sucks and is extremely rough. Boost response is 10 times better than that of the GSR's. I am using a T70 turbo and it starts to spool at around 4500 and will make power all the way to 13,000 RPM's. I would highly suggest getting turbo cams. A low overlap/high lift cam will produce tons of power if you have the internals to support it. Well worth the investment. Skunk2 turbo cams would be similar just not as benificail as the cranes. I'm sure it would make good power to at least 10,000.
Re: (ms1motorsports)
hey thank you for giving me a real answer! i really appreceiate it! anyone else have turbo cams?
Re: (gsrpwr2004)
Why not go with BLOX Turbo Cams? I'll be using them in my Turbo Setup.
https://honda-tech.com/zerothread?id=1007259
