any last things i should know that would make turbo install easier
i have to wait for this place that told me they would have my bolts ready to get them @ 12, so i am seeing if there are any problems i should know that i might run into, or if there is anything that can make it easier? thanks guys
brian
brian
Re: any last things i should know that would make turbo install easier (ZCHF)
Don't get your hopes up for a one day install. Be ready to make several trips to the hardware store/Napa. Take your time.
Re: any last things i should know that would make turbo install easier (Farnsrocket)
well here is the progress. day one, made my own bolts to fit to the adapter, and bolted the turbo up to the engine. a little tight on space but i think it should work. Didnt run any lines yet but going to try that tommorow. Hacked up some space for the dsm ic to fit but it still doesnt fit. (more sawzalling tommorow). That is where i am at. Once i get the ic in i will tie everything together and then install the injectors and the smc. i hope that everything goes ok. wish me luck.
have u ran yer feed line yet? if not, take your time with this...this was one of the easiest but most frustrating because of space. take a lot of breaks and make sure u have a third day to work out all the kinks...
Re: any last things i should know that would make turbo install easier (Racerage1)
havent ran it yet but am going to try and run it today. hoping that today i will at least get everything installed, and running, and then i have tommorow and sunday to get it tuned properly. i sure hope everything goes well. thanks guys
lucas569
07-15-2002 09:57 PM
