any ever use hondata s300 boost controller./?
Old Feb 28, 2007 | 02:57 PM
THEDirtyDseriesWOOT's Avatar
Default any ever use hondata s300 boost controller./?
ok i have a greddy profec ebc and i love it but i just got hondata s300 and i heard i can use a gm solenoid to control the boost.. the reason i wanna switch is beacue i want boost by gear.. gredyy has the hi/lo but.. i dont wanna have to hit a damn button to change it while shifting to third.. is there anyway i can hook the gredyy box to the ecu to change form high to low boost by gear? if not who uses the s300 ebc and how do you like it ive heard bad about both.
Old Feb 28, 2007 | 03:36 PM
mtber's Avatar
Default Re: any ever use hondata s300 boost controller./? (THEDirtyDseriesWOOT)
The greddy profec e01 can do boost by gear also...
Hondata s300 can be setup to use a switched input for a high & low boost setting via boost by gear :-)
Old Feb 28, 2007 | 03:50 PM
?? how do i do this elaborate im new to the hondata thing pm me.. and its a profec b2 it doesent have that capability .. just high low boost with a gournd switch.. how do i set that up where it will chang eit for me.. and how do i wire it up
Old Feb 28, 2007 | 04:39 PM
ladysman's Avatar
Default Re: (THEDirtyDseriesWOOT)
http://www.hondata.com/s300boostcontrol.html
You can't hook the greddy up to it. You need the GM Solenoid or I hear the Apexi solenoid works well.
Old Feb 28, 2007 | 04:43 PM
ive read that crap it tells me nothing...
i know in neptune u can hook it up to a output signal liek the n20 controll kinda and make it switch form high to low boost using the greddy controller.. its just a ground switch? can it work with hondata
Old Feb 28, 2007 | 04:52 PM
turbovt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote"> greddy profec e01 can do boost by gear also... </TD></TR></TABLE>
I have had my profec eo1 for 3 years and last time i checked it can not do boost by gear.
Modified by turbovt at 6:09 PM 2/28/2007
Old Feb 28, 2007 | 05:11 PM
tony1's Avatar
Default Re: any ever use hondata s300 boost controller./? (turbovt)
The S300 boost control setup works great. I prefer the AEM solenoid with it. Boost by gear, and the ability to toggle between to pre set boost by gear maps with a switch. Pretty much can't get a boost controller capable of doing what it does, as well as it does, for less than $700. That single reason in itself should be enough for anyone with 350+hp to justify getting an S300.
Old Feb 28, 2007 | 05:45 PM
Default Re: any ever use hondata s300 boost controller./? (tony1)
http://www.hondata.net/forum/viewtopic.php?t=3938
it can be done with n20 controls atleast.. i can set it to a mph to activate whatever mph my third gear hits when i shift..
ok so i know it can be done.. now how do i wire it up .. profec needs a ground signal.. do i just hook a wire to the profec then to the ecu pin that i use I.E. ac clutch pin. and at soo many mph does the ecu send a ground signal to the profec changing it.. somthihng about a relay or somthign they talked about at the hondata site?? i need a damn diagram..
Old Feb 28, 2007 | 06:06 PM
FactionR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEDirtyDseriesWOOT &raquo;</TD></TR><TR><TD CLASS="quote">ive read that crap it tells me nothing...</TD></TR></TABLE>
its all there, what arent you understanding? the wiring? its there...
Old Feb 28, 2007 | 06:20 PM
nono i dont want to use the gm solenoid i want to use my profec and have the s300 send a signal to it to change from low to high boost at a certain mph via the nitro control...
Old Feb 28, 2007 | 08:47 PM
Dunc's Avatar
BCICAN
Just got off the dyno today actually and was setting it up. The GM solenoid works very well. It's holds boost well and is easy to wire up. You can use a variety of solenoids if you set them up correctly.
Old Feb 28, 2007 | 08:51 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbovt &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by turbovt at 6:09 PM 2/28/2007</TD></TR></TABLE>
I was under the impression that the e01 units now had boost by gear options like an avcr. I guess not
Old Feb 28, 2007 | 08:59 PM
vti2's Avatar
Default Re: any ever use hondata s300 boost controller./? (mtber)
Does anibody tried the Apexi solenoid?
Old Mar 1, 2007 | 07:25 AM
locash's Avatar
Default Re: any ever use hondata s300 boost controller./? (vti2)
Yup, the Apexi solenoid works fine as well..
Old Jun 25, 2007 | 07:34 PM
darkdemon215's Avatar
Default Re: any ever use hondata s300 boost controller./? (locash)
can some 1 post a how to hook up the apex with a duel wastegate
Modified by darkdemon215 at 9:13 PM 6/25/2007
Old Jun 25, 2007 | 09:25 PM
V-SPEC 1's Avatar
Default Re: any ever use hondata s300 boost controller./? (darkdemon215)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkdemon215 &raquo;</TD></TR><TR><TD CLASS="quote">can some 1 post a how to hook up the apex with a duel wastegate
Modified by darkdemon215 at 9:13 PM 6/25/2007</TD></TR></TABLE>
Old Jun 26, 2007 | 11:40 AM
turboteener's Avatar
Banned
Why not use the output from the S300 to trigger the switch you need for high and low boost.
blues-eg
Feb 11, 2010 04:34 PM
Pompiuses
Dec 30, 2009 12:36 PM
purpleh22
Oct 18, 2009 01:34 PM
xander1100
Engine Management and Tuning
19
Feb 15, 2009 08:52 AM
5thgencivic
Sep 17, 2003 06:41 PM
