Another turbo selection thread
Old Sep 17, 2007 | 06:49 PM
CivicVX94's Avatar
Default Another turbo selection thread
First I HATE having to post this up, but I guess I need to.
The basics of my build consists of an 84x89mm c1 block (compression ratio will be determined shortly)/pnp b16 head/sheetmetal intake manifold/76mm t body/top mount t3 mani/4''dp/competition stage 5 clutch with upgraded pressure plate
For the basis of this thread that should be all the matters.
Anyways, i'm shooting for 550wp this season, reason being is not enough $ for twin disc clutch or a large enough turbo to flow that much.
I have about $800 to spend on a turbo and I have a few choices but I want to be sure before I drop the cash.
First off, recommended by my tuner is a Holset HX35 with the 12cm housing. I can't find ANYWHERE that sells these new! I skimmed the holset thread but it's like 80 pages long and I don't have the time to read thru all that. I've also read that the HX35 12cm exhaust housing with 3'' v band with the HX40 compressor housing is a beastly combo, but once again the issue of finding one.
I don't prefer not to buy a used turbo that I need to rebuild and have to weld the internal wg flapper shut, but at this point whatever I find I will work with.
Next is the kinetic t3/gt40, new the go for a little less than 800 and have a year warranty. it's basically a non-ballbearing gt35r, here's the options they have for that...
T3/GT40 - T3/T61
Compressor Wheel: 56 Trim GT40 (Inducer 61mm/Exducer 82mm)
Compressor Flow: 65lbs/min
Compressor housing: 60A/R or 70A/R
Turbine Housing: (48ar, 63ar, 82ar)
Turbine Flange Configuration: (4bolt, 5bolt)
Turbine Wheel: (Stage 3 or P trim)
Center Section: Oil Cooled Journal Bearing with 360 degree thrust bearing
Which do you think would be best?
Any good spots to find new Holset turbo's or rebuild parts (wheels/housings)?
I'm open to any options and thanks in advance for any help
Old Sep 17, 2007 | 06:53 PM
HighRevn's Avatar
Default Re: Another turbo selection thread (CivicVX94)
Idlike to know more about the kinetic turbo also, sounds interesting, got a link?
Old Sep 17, 2007 | 07:06 PM
CivicVX94's Avatar
Default Re: Another turbo selection thread (HighRevn)
No, it's not up on their site yet, but pm "ITS_DUNN" and he can help you out
Old Sep 19, 2007 | 06:30 PM
CivicVX94's Avatar
ttt
Old Sep 19, 2007 | 07:43 PM
TheShodan's Avatar
Moderator
If you get the above listed turbo. Get the P-trim wheel... That may add to your cost, though, but much more efficient for that power range.
Mr.Kalinchuk
Mar 27, 2009 09:22 AM
doc
Dec 14, 2005 11:28 PM
Pelican
Dec 18, 2003 01:53 AM
its WANG yoO
Oct 21, 2002 09:36 PM
