another noob
Old Feb 26, 2008 | 09:22 AM
92VXeg's Avatar
Default another noob
Im sure this has been covered more than 100 times but i cant get a good search out of it. I just bought i complete LS swap and want to get the motor work done before i put it in. Im going to put 3000 budget into the block/head. Im going boost. Trying to do it right the first time.
Should i put the swap in and make sure everything is fine before i do anything with it? Its from a good friend who got it out of a stock integra so i dont know how much could be wrong with it.
The only thing about putting it in taking it out and putting it back in is that i have limited resources and dont have another vehicle to drive so im trying to avoid that by building before i drop it.
With the budget in mind i what to know what kind of work i should do do use a 8lbs of boost reliable car. Should i track down a head that is already semi built and go from there or just do it all myself?
Old Feb 26, 2008 | 09:23 AM
92VXeg's Avatar
Default Re: another noob (92VXeg)
forgot to mention that this is going in a 92civic VX hatch. no preformace upgrades other than dome rear disc swaps.
Old Feb 26, 2008 | 09:45 AM
HarfordCTR's Avatar
First you gotta let us know what kinda power goal you are going for.
Old Feb 26, 2008 | 09:46 AM
Schister66's Avatar
Man U FTW
First of all, what is your power goal?? PSI doesn't have any relevance when you're determining your goals...you need to have a horsepower goal in mind. What is your budget for the turbo setup? For the engine build?
Depending on your goals, you may not have to build the engine....i made 315whp on a stock GSR. The rule of thumb for any stock B series is that they're good to about 300whp in stock form.
Old Feb 28, 2008 | 05:09 AM
92VXeg's Avatar
yea sry i want about 275
Old Feb 28, 2008 | 06:58 AM
dcomer04's Avatar
Default Re: (92VXeg)
noob here....
i joined honda-tech 6 days ago and i'm still banned from pm....how long does it take before i can reply in the for sale???
i know this is a little of topic....
Old Feb 28, 2008 | 07:05 AM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92VXeg &raquo;</TD></TR><TR><TD CLASS="quote">yea sry i want about 275</TD></TR></TABLE>
If the motor is in good condition (and you have run the checks and maintanence necessary to ensure of this), then there is no need to do anything to the head or block to make that kind of power based upon the budget you're using.
Draiga1988
11
Apr 1, 2011 11:24 AM
foowitdaredek
May 1, 2009 05:39 PM
HondaKid936
Apr 25, 2009 02:14 PM
[[Anthony]]
21
Oct 23, 2006 10:00 PM
carl_aka_carlos
Aug 12, 2002 10:51 PM
