amount of oil to use with turbo on...
Old Jan 16, 2004 | 03:12 PM
xXx Justin xXx's Avatar
Default amount of oil to use with turbo on...
ok, this might sound dumb. but stock d16z6, y8, y7... whatever. take 3.5qts when oil change time comes. how much oil does the turbo feed line, turbo itself and all hold? im thinking that with only 3.5 qts. b/c some of that oil is being distributed elsewhere, the normal oil pressure the rest of the engine should have is lower. anybody ever think about that?
wonder if it would be good to run an extra 1/4 of a qt. or maybe even 1/2 qt. depends on turbo size and feed line length i guess? maybe strupid thought. just wanted to get others opinions on this
Old Jan 16, 2004 | 03:24 PM
baphomet's Avatar
Default Re: amount of oil to use with turbo on... (SOHC Beast)
Just keep adding until it is at the appropriate level on the dip stick, start the car, shut it off and check the stick again, add some more etc.
Old Jan 16, 2004 | 04:43 PM
Default Re: amount of oil to use with turbo on... (slashDEVslashNULL)
yea, a friend of mine brought up a good point i think. he said to check how much a 1g 2.0L N/A eclipse has. then check the same engine for FI. and see what the difference is. the difference is a good idea of how much more to add since the DSM turbo and greddy turbo... and feed lines are all about same... would be a very good estimate for the difference in oil to use...
i just noticed it takes a little longer for the ticking to go away on a very cold start... just seems like there is less pressure or something...
Old Jan 16, 2004 | 04:52 PM
rtype11's Avatar
the difference is negligible, like slash said you check the oil level, dont add past the max marker on the dipstick. I take a guess and say the whole turbo oiling system uses a dixie cup full of oil max, the turbo doesnt fill with oil its shaft just floats on oil.
Old Jan 17, 2004 | 03:45 AM
Default Re: amount of oil to use with turbo on... (rtype11)
ok..... it was just a thought to see if it might be helpful. thanks though
team2dcrx
Jun 17, 2014 12:15 PM
roachsboosted16
Oct 3, 2010 10:24 AM
sleevedgsr
Nov 29, 2004 09:05 AM
Blkteg97
Nov 16, 2004 08:04 AM
slo_crx
Oct 12, 2004 05:51 PM
