Am I need oil restrictor for a GT3071R ???
i am asking that now because my car have 200kh only with maximum 3000 rpm.
am i need a oil restrictor with my GT3071R??
I have conented and the water lines too.
the oil line i used is custom...about 3mm internal hole.
i have to install oil restrictor or no?? in the specs into the Garrett site it says 0.4375IN-24 thread for 6.35 tube.
if i need this, where i can buy it?
Re: Am I need oil restrictor for a GT3071R ???
Ok so I finally need a 0.35" oil restrictor!
I saw the oil inlet before I install it to my car and
It had something like oil restrictor inside the hole.
For this reason the guy (stupid) told me to didn't use oil restrictor.
TheShodan this inside the turbo seems like oil restrictor... For what reason is there??
this is ok for me??
http://cgi.ebay.com/ebaymotors/Fitti...Q5fAccessories
this is ok for me??
my turbo seller here tell me that it dont need any restrictor...it has built in and you can add or not oil restrictor....
aaaa my head....what really needs?
Moderator
Yes, you need the oil restrictor, and your turbo seller is NOT thinking of the particular oil pressure of a Honda turbocharged engine. In addition, the one that you've chosen is an aluminum fitting, which has been severely known to cross-thread on installation. Please avoid this one.
The one you want to use is here.
http://www.atpturbo.com/mm5/merchant...gory_Code=GTBB
It is for a -3AN line, but uses a -4AN flare.
I'm not going to go through a debate between yourself and your turbo seller. You want to do it, great, if not, that's a helluva gamble with a $1300 piece of equipment. This is how its done properly for longevity of the turbocharger. GL.
i will hear you my friend because the turbo seller wants to sell..
can i install it at 1000 km??? now i have 250 km.
i said that because everything is new and i drive with very low rpm (the gauge oil press says max 70 psi)
i search for a male/female restrictor....but nothing..
ok TheShodan i already bought this oil restrictor
please someone tell me which side fit into the turbo?? the size with the big hole or the side with the small??
i asked that beause tommorow i am going to buy the fittings and the oil line and i cant
remove first the already installed line...
