All of a sudden throwing 2 codes. Code 20 Electrical Load Detection and Code 21 vtec spool solenoid
Old Apr 26, 2005 | 08:32 PM
SOHC_MShue's Avatar
Default All of a sudden throwing 2 codes. Code 20 Electrical Load Detection and Code 21 vtec spool solenoid
For some reason now my car is randomly throwing these codes whenever I let my rpms go above around 6000 rpms and there has to be a good bit of load on the engine...like at full throttle. Both of the codes are being thrown at the same time. Any idea whats going on?
Old Apr 26, 2005 | 08:35 PM
93turbo16's Avatar
Default Re: All of a sudden throwing 2 codes. Code 20 Electrical Load Detection and Code 21 vtec spool sole
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">For some reason now my car is randomly throwing these codes whenever I let my rpms go above around 6000 rpms and there has to be a good bit of load on the engine...like at full throttle. Any idea whats going on? </TD></TR></TABLE>
Your car is cursed.
That seems very weird though, most likely electrical? Possibly alternator.. I have seen more retarded things.
Old Apr 26, 2005 | 08:37 PM
SOHC_MShue's Avatar
yea i am so sad. My car has ran perfect until now . I was thinking alternator too. I tightened the belt a couple of days ago because it was squeeling....actually the same day i first noticed the code.
Old Apr 26, 2005 | 08:38 PM
SOHC_MShue's Avatar
It also feels like my top end completely falls off when it throws this code...like maybe vtec disengages.
93turbo16's Avatar
Might as well take it off and get it checked out.
yea, that would make sense, if you are throwing that code.
Also some battery testers have an ALT tester on them. Might as well take it to auto zone or something.
Old Apr 26, 2005 | 08:43 PM
Built Beast's Avatar
Damn that sucks Matt...
Old Apr 26, 2005 | 08:54 PM
SOHC_MShue's Avatar
Default Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">Might as well take it off and get it checked out.
Also some battery testers have an ALT tester on them. Might as well take it to auto zone or something.</TD></TR></TABLE>
yea my buddy sais he has something that we can test it with tomorrow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R33CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">Damn that sucks Matt...</TD></TR></TABLE>
Tell me about it...
Old Apr 26, 2005 | 09:04 PM
raene's Avatar
I already replied on the uber forum, but the reason it throws a vtec solenoid code is because the vtec wire is becoming disconnected. It's probably loose. When the car gets slower, it's probably because the wire fell off so vtec turned off.
Old Apr 26, 2005 | 09:09 PM
SOHC_MShue's Avatar
I've checked and its definintly not coming off. Like I said i only get the code in really high rpms at high load. If I turn the car off then the code goes away. I can still hear vtec engage.
Old Apr 26, 2005 | 09:51 PM
SOHC_MShue's Avatar
Could this have anything to do with my tightening my alternator belt the other day because it was squeeling?
Old Apr 26, 2005 | 10:11 PM
SOHC_MShue's Avatar
check out the obd2 codes list...under the vtec malfunction section.
VTEC System Malfunction
P1297 Electric Load Detector (ELD) Circuit Low Voltage
P1298 Electric Load Detector (ELD) Circuit High Voltage
P1300 Random Misfire
P1324 Knock Sensor Power Source Circuit Low Voltage
P1336 Engine Speed (RPM) Fluctuation Sensor Intermittent Interruption
P1337 Engine Speed (RPM) Fluctuation Sensor No Signal
P1355 Front Ignition Coil Power Circuit Malfunction
P1359 Crankshaft Position (CKP)/Top Dead Center (TDC) Sensor Circuit Malfunction
P1361 Camshaft Position (CMP) Sensor A (Top Dead Center (TDC) Sensor) Intermittent Interruption
P1361 Top Dead Center (TDC) Sensor Intermittent Interruption
P1362 Camshaft Position (CMP) Sensor A (Top Dead Center (TDC) Sensor) No Signal
P1362 Top Dead Center (TDC) Sensor No Signal
P1366 Camshaft Position (CMP) Sensor B (Top Dead Center (TDC) Sensor) Intermittent Interruption
P1366 Top Dead Center (TDC) Sensor 2 Intermittent Interruption
P1367 Camshaft Position (CMP) Sensor B (Top Dead Center (TDC) Sensor) No Signal
P1367 Top Dear Center (TDC) Sensor 2 No Signal
P1381 Cylinder Position (CYP) Sensor Intermittent Interruption
P1382 Cylinder Position (CYP) Sensor No Signal
P1410 Air Pump Malfunction
P1415 Air Pump Electric Current Sensor Circuit Low Voltage
Look at the first 2....they seem to have something to do with the ELD. I'm guessing thats why i am getting code 21 along with 20.
Modified by SOHC_MShue at 2:25 AM 4/27/2005
Old Apr 27, 2005 | 05:30 AM
SOHC_MShue's Avatar
bump
Old Apr 27, 2005 | 08:11 AM
raene's Avatar
You know I had a similar problem when I first went turbo... for the damn life of me I can't remember what the solution was. I'll post if I remember... sorry
Until then, bump for you!
Old Apr 27, 2005 | 08:41 AM
EE_Chris's Avatar
P1182 Fuel Temperature Sensor Circuit Low Voltage
P1183 Fuel Temperature Sensor Circuit High Voltage
P1253
P1259
There isn't a section called 'VTEC System Malfunction' - someone hit the enter key as P1253 and 1259 are both for VTEC.
You had mentioned in another thread that you had to tighten the alternator belt - perhaps there is some coincidence between that action and this code. Perhaps your alternator is on its way out.
Old Apr 27, 2005 | 09:08 AM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">You know I had a similar problem when I first went turbo... for the damn life of me I can't remember what the solution was. I'll post if I remember... sorry
Until then, bump for you!</TD></TR></TABLE>
if you remember let me know. I would really appreciate it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">
You had mentioned in another thread that you had to tighten the alternator belt - perhaps there is some coincidence between that action and this code. Perhaps your alternator is on its way out.</TD></TR></TABLE>
yea i'm gonna try loosening it today and see what happens. Any idea why this is related to the vtec spool solenoid code though?
Old Apr 27, 2005 | 11:36 AM
SOHC_MShue's Avatar
Ok well loosening it didn't work. It just made the belt squeel. Now that i tightened it back up it still squeels so it looks like its time for a new alternator belt.
Old Apr 27, 2005 | 01:13 PM
SOHC_MShue's Avatar
bump
Old Apr 27, 2005 | 06:44 PM
SOHC_MShue's Avatar
still no luck...
Old Apr 28, 2005 | 06:40 PM
SOHC_MShue's Avatar
i thought it was fixed, but its not. Anymore ideas guys?
Old Apr 28, 2005 | 08:10 PM
SOHC_MShue's Avatar
bump
Old Apr 28, 2005 | 09:29 PM
SOHC_MShue's Avatar
well i ran a wire to the vtec solenoid and it clicked so i guess that is working fine. Whenver the cel comes on vtec is definintly disengaging. Then it won't turn on after that until i turn the car off and reset the cel.
Old Apr 29, 2005 | 02:30 PM
Still no luck?
Old Apr 29, 2005 | 09:00 PM
SOHC_MShue's Avatar
Well i figured out what it is today. My ecu has something shorted out in it. I tried my buddy's ecu with my chip today and it runs great. I think this guy's prelude i was tuning shorted something out in my ecu when i was datalogging with it.
Old May 18, 2005 | 12:24 PM
xenocron's Avatar
Ever figure out what your shorted?
em1gangsta
Jun 27, 2008 06:42 AM
DarkBB4
May 7, 2007 03:06 PM
Senbonzakura
Aug 27, 2006 01:16 AM
SOHC_MShue
16
Apr 30, 2005 12:58 PM
