All of the sudden....LEAN
Old Apr 27, 2004 | 01:10 PM
wtc7676's Avatar
Default All of the sudden....LEAN
Well the car had sat for about 2 days...went to drive it and I noticed my a/f meter read all the way lean ( I know its not accurate), it had never read that. I figured it was just the gauge, so I took it around the block, it started to hesitate bad, so it must be running lean...I pulled my spark plugs but they look fine, nice brown color.
Fuel pressure idle is 50 psi
Any ideas?
Setup
93 civic
95 JDM Gsr motor swap (Stock)
JRSC kit 6 psi.
255 holley fuel pump
New AEM fuel filter
aem fpr
aem fuel rail
stock injectors
MSD SCI ignition
Blaster ss coil
I have an AEM EMS and UEGO controller that I want to install but I need to get this problem fixed first.
Thanks
Will
Old Apr 27, 2004 | 02:03 PM
delslowh23's Avatar
Default Re: All of the sudden....LEAN (wtc7676)
you need more fuel uping your fp doesn't cut it fmu or bigger injector seen you have a AEM just get bigger injector
Old Apr 27, 2004 | 02:06 PM
wtc7676's Avatar
Default Re: All of the sudden....LEAN (delslowh23)
It has the JRSC fmu, that came with the kit. The car was running great just all of the sudden it started running lean.
Old Apr 27, 2004 | 02:20 PM
HybridKOOP's Avatar
Most likely a faulty regulator if no other changes have been made to the car recently.
I wouldn't rely too heavily on a standard A/F gauge. Get yourself an EGT setup
Old Apr 27, 2004 | 02:23 PM
wtc7676's Avatar
Default Re: All of the sudden....LEAN (HybridKOOP)
I have my fuel press. gauge on the fuel rail...when I adjust the regulator, the pressure still goes up or down...how would I test for a bad fpr.
Old Apr 27, 2004 | 02:26 PM
91civicDXdude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">you need more fuel uping your fp doesn't cut it fmu or bigger injector seen you have a AEM just get bigger injector
this made absolutely no sense seeing as how an FMU *RAISES FUEL PRESSURE* which you say "wont work"
Old Apr 27, 2004 | 02:46 PM
HybridKOOP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wtc7676 &raquo;</TD></TR><TR><TD CLASS="quote">I have my fuel press. gauge on the fuel rail...when I adjust the regulator, the pressure still goes up or down...how would I test for a bad fpr.</TD></TR></TABLE>
It'd be much easier to see whats going on if the gauge were inside of the cars cabin... that way you could see how your fuel pressure reacts to boost (should rise quickly as boost comes in with the FMU).
Try swapping our regulators with a buddy of yours... a stock regulator should be ok as long as you have the FMU installed correctly.
Old Apr 27, 2004 | 03:06 PM
wtc7676's Avatar
I just found my timing light, and checked my timing, I had originally set it at 10 but when I just checked it, it was at 18 ( anyone know why?) So I set it back to 10 (using the dist.) and it still shows lean on the a/f gauge and it still hesitates.
I had my buddy, look at the guage while I pushed the gas...at part throttle, little or no movement, at wot, it shoots up good.
I am at a loss.
Old Apr 27, 2004 | 04:40 PM
wtc7676's Avatar
bump
Old Apr 27, 2004 | 05:51 PM
sporkcrx's Avatar
Default Re: (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslowh23 &raquo;</TD></TR><TR><TD CLASS="quote">you need more fuel uping your fp doesn't cut it fmu or bigger injector seen you have a AEM just get bigger injector</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">
.....</TD></TR></TABLE>
allow me to translate
"You need more fuel, uping your fp (with a fpr) doesn't cut it. FMU or bigger injectors, and seeing that you already have an AEM, just get bigger injectors."
Bay_707
Jan 27, 2005 11:53 PM
S88HON
Oct 22, 2004 12:09 AM
FastNFurious
Apr 12, 2003 05:54 PM
Bigstothel
May 31, 2002 10:53 AM
