are all b-series clutches the same?
Old Nov 7, 2001 | 05:54 AM
newsense's Avatar
New User
Default are all b-series clutches the same?
im putting a quaife in and i noticed that the clutch has some wear on it... my homeboy has a brand new clutch for an older ls (cable) and i was curious if this will work... i need it running my this weekend so if this clutch wont work im gonna have to keep the one thats in there... does anyone know if this will work?
Old Nov 7, 2001 | 05:59 AM
Davep's Avatar
Default Re: are all b-series clutches the same? (newsense)
90-91 (small spline) are different from the 92+ (big spline)
Old Nov 7, 2001 | 06:19 AM
newsense's Avatar
New User
Default Re: are all b-series clutches the same? (Davep)
if the 92 has the same size spline as the 94.... than that means its useable
Old Nov 7, 2001 | 07:27 AM
VaporTrail's Avatar
New User
you got it cheif
Old Nov 7, 2001 | 07:44 AM
newsense's Avatar
New User
Default Re: are all b-series clutches the same? (VaporTrail)
thanks... i appreciate the help guys!!
Suprdave's Avatar
OK, I have a Y1 on my B18B...I bought a Clutchnet Stage 2 from Ben...He Figured the Clutch Situation out for me...
I'm guessing that he paired a Small Spine Disk with a Normal Pressure Plate...Correct? So when I switch back over to a Hydro Trans, I need a new Disk...Right? I can re-use the PP though. Thanks
Suprdave
Old Nov 7, 2001 | 07:54 AM
VaporTrail's Avatar
New User
Default Re: are all b-series clutches the same? (Suprdave)
Suprdave
You got it. All B series use the same pressure plate, but if you use a transmission from 1990-1991, the splines are smaller on the clutch disc.
Old Nov 7, 2001 | 08:05 AM
TypeC's Avatar
Suprdave
just adding, any '89-91 B-series (JDM too cable tranny's included).
also, the '89-91 trannys need their respective starter ('92+ won't work without modification). That's a pain in the *** when you're all done with a swap/rebuild. [this is all misc tidbits that don't relate to the question]
-C
818SpoonITR
Sep 15, 2007 12:25 AM
synner
Aug 12, 2007 08:08 PM
Stillo
Oct 6, 2006 08:19 PM
REDBARON
Jan 21, 2002 09:09 AM
