Air/Fuel Ratios??
Old Oct 28, 2005 | 05:23 AM
irocdaparty85's Avatar
Default Air/Fuel Ratios??
After my Lude was tuned I was told to expect my air/fuel ratio to read around the High 13's / low 14's while at idle and cruising, b/c h22's run better on the rich side.
now, two months later, with the temperature dropping in PA, I'm noticing that my ratios are wandering into the upper 14's and occasionally into the 16's for a second. Is this normal to see with the cooler/denser air?? Or do I need a retune, or to fix something??
thanx for any help
Old Oct 28, 2005 | 05:43 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Air/Fuel Ratios?? (irocdaparty85)
when it gets cold and more dense, your a/f may rise.
Old Oct 28, 2005 | 06:25 AM
But is that a bad thing...or just normal.
Old Oct 28, 2005 | 06:29 AM
adseguy's Avatar
Default Re: (irocdaparty85)
I'm guessing you are tuned on Uberdata or Crome. Don't worry about A/F's when you are just driving around with no load. As long as you are not missing (lean missfire) you'll be fine. Make sure when in boost or have a big load on the car without boost the AF's are in the 12.2 or lower
Old Oct 28, 2005 | 06:59 AM
Mr. Badwrench
Default Re: (adseguy)
nah it is hondata and as long as the a/s's are still good under boost youll be ok.
Old Oct 28, 2005 | 07:57 AM
boosted k20's Avatar
Default Re: (boostedcivicsir)
to do a quick fix w/o a retune, just bump up the fuel pressure a bit (try increasing it by 5psi)
Old Oct 28, 2005 | 08:23 AM
stirnice's Avatar
IAT correction tables are found at 0x5516(low load); 0x5531(medium load); 0x554c(high load).
It follows a temperature, Correction(word, not byte), temperature, correction, temperature, correction....pattern.
Anyone with a little motivation, logic, and computer knowledge should be able to handle hex editing the ROM. Another big hint is to use whats available to you(download sManager, Crome, and Uberdata....should give you big hints, especially since uberdata and crome's scripts are able to be opened in word pad)
Old Oct 28, 2005 | 10:36 AM
Yes it's a hondata s200 on a P72. Thanks for all your input.
a few more Q's -
How do you increase the fuel pressure? All this tuning stuff is foreign to me....
and also - doesn't the new s300 system compensate for atmospheric changes??
91crxturbo
Jan 8, 2007 04:48 PM
InJ3cted
Apr 23, 2006 11:09 AM
bard329
Feb 22, 2006 07:02 AM
Benjithx
Jan 13, 2005 10:08 AM
ZCHF
Mar 1, 2003 03:20 PM
