Aid with Turbo Components
Old Sep 12, 2008 | 10:31 AM
ware's Avatar
Default Aid with Turbo Components
1 I just purchased a TD05H, it didn't come with a wastegate. Does anyone know if these are internal or external?
2 As far as manifolds, does anyone know of one that would clear A/C and Power Steering? This will be on a 00' EX coupe. Stock d16y8
Thanks Fellas
Modified by ware at 12:45 PM 9/12/2008
Old Sep 12, 2008 | 10:57 AM
Civicman86's Avatar
Default Re: Aid with Turbo Components (ware)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ware &raquo;</TD></TR><TR><TD CLASS="quote"> 1 I just purchased a TD05H, it didn't come with a wastegate. Does anyone know if these are internal or external?
Thanks Fellas </TD></TR></TABLE>
1.internal, you can make it external if you want by just welding the flapper shut.
2.Engine/Chassis would help. In today's age there are like 20893290482349023 manifold available. I'm sure you can find a few that will work for you application.
Old Sep 12, 2008 | 11:00 AM
thatblkguy's Avatar
TDO5H? need more info
What turbo is it?
Old Sep 12, 2008 | 11:48 AM
ware's Avatar
Default Re: Aid with Turbo Components (Civicman86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicman86 &raquo;</TD></TR><TR><TD CLASS="quote">2.Engine/Chassis would help.</TD></TR></TABLE> Updated the post, forgot to add the chasis in my original post.
-2000 honda civic ex stock d16y8
Old Sep 12, 2008 | 01:49 PM
TheShodan's Avatar
Moderator
Default Re: (thatblkguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thatblkguy &raquo;</TD></TR><TR><TD CLASS="quote">TDO5H? need more info
What turbo is it?</TD></TR></TABLE>
Old Sep 12, 2008 | 03:36 PM
ware's Avatar
Default Re: (TheShodan)
14b turbo. Up for options
Old Sep 12, 2008 | 04:00 PM
thatblkguy's Avatar
internally gated
You have two choices of manifolds
1. make your own log
2. buy one flanged for a dsm turbo off ebay
http://homemadeturbo.com/ Is your home for 14b set ups
I hope you dont have big power goals
Old Sep 12, 2008 | 04:13 PM
ware's Avatar
Daily driver. 170-180ish is my goal. Mainly looking for torque. Thanks for the help
Old Sep 14, 2008 | 09:33 AM
ware's Avatar
Default Re: (ware)
Does anyone know if there is a manifold out there that would clear a/c and power steering for this 14b on a d16y8?
Old Sep 14, 2008 | 05:31 PM
TheShodan's Avatar
Moderator
^^ Not without an adapter plate and some fab work. Those "cheap" car builds never turn out to be that way in the end.
Old Sep 17, 2008 | 04:20 PM
ware's Avatar
Hmm i found this mani. All i would need would be the adapter plate... What do you guys think?
http://cgi.ebay.com/ebaymotors...15129
Old Sep 17, 2008 | 09:04 PM
ware's Avatar
Default Re: (ware)
Old Sep 18, 2008 | 11:19 AM
thatblkguy's Avatar
http://cgi.ebay.com/ebaymotors...wItem
Old Sep 18, 2008 | 12:15 PM
ware's Avatar
Thanks man! Really appreciate the help. Do you think that will clear A/c and power steering though?
Old Sep 18, 2008 | 09:50 PM
ware's Avatar
Default Re: (ware)
is this mani any good? Is the wastegate flange in a bad position?
http://www.go-autoworks-store.com/gocairtuma.html
Old Sep 19, 2008 | 08:33 AM
TheShodan's Avatar
Moderator
Default Re: (ware)
Might as well try it. It's inexpensive, so why not?
Old Sep 20, 2008 | 09:00 AM
ware's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">Might as well try it. It's inexpensive, so why not?</TD></TR></TABLE>
Well i've been told that the wastegate flange in that position will cause problems. What you guys think?
Old Sep 22, 2008 | 07:22 AM
ware's Avatar
Default Re: (ware)
Looks like im going to try this one out.. any opinions?
http://cgi.ebay.com/ebaymotors...90393
Old Sep 22, 2008 | 08:58 AM
thatblkguy's Avatar
go for it you still need the adapter plate and external wastegate. And your going to to have to weld up the turbo for external wastegate use
Old Sep 22, 2008 | 11:01 AM
ware's Avatar
I would just have to get the flapper shut correct?
Old Sep 22, 2008 | 11:15 AM
thatblkguy's Avatar
YES
Old Sep 22, 2008 | 11:24 AM
ware's Avatar
EK FLY
Jul 8, 2006 06:26 AM
comingupfast
Dec 19, 2005 12:12 AM
Bartman201
Dec 30, 2004 11:04 PM
Dasani
Apr 1, 2004 07:31 AM
ThePunk
Jun 25, 2003 09:48 AM
