is an aftermarket ignition needed?
Old Apr 27, 2004 | 01:02 PM
DubyaAye's Avatar
Default is an aftermarket ignition needed?
is an aftermarket ignition needed for my goals? my goals are to make around 250-300 whp on a stock b16 with hondata s200b.
Old Apr 27, 2004 | 02:06 PM
Chillinit's Avatar
Default Re: is an aftermarket ignition needed? (DubyaAye)
not needed...you should be fine for that kind of power. I'm about to turbo my gsr and have a crane ignition in my garage however I am sticking with my stock ignition.
Old Apr 27, 2004 | 02:25 PM
Rod.'s Avatar
Default Re: is an aftermarket ignition needed? (Chillinit)
I believe you can have 400hp with stock ignition. Do not give up on stock stuff, some of it can last for a while
Old Apr 27, 2004 | 03:35 PM
Harry Doyle's Avatar
It may be possible to run those numbers without an after market ignition, but with an msd you will get a stronger more efficient spark. I ran no msd while making around 350 whp, and my car ran like ****. Car ran much smoother after installing the aftermarket ignition.
redline1219
Feb 12, 2011 11:21 AM
turboman
Apr 14, 2006 02:37 PM
XX Boosted Si XX
Dec 7, 2005 02:50 PM
dunkd
Aug 9, 2004 05:25 AM
r2fst4u
Jun 23, 2002 05:43 PM
