Wideband after cat?
Old Apr 27, 2004 | 08:04 AM
warwagon's Avatar
Default Wideband after cat?
Just curious what kind of readings happen if you put your o2 after the cat on a wideband? I don't have any way of putting the sensor before the cat and i am wanting to put my injectors in and tune my vacuum columns while i am still waiting for my shorty and dp.
Old Apr 27, 2004 | 09:37 AM
gritsak's Avatar
Default Re: Wideband after cat? (warwagon)
putting it after the cat would not be a good idea...why dont you have any way of putting it in before the car? just get a bung welded in
Old Apr 27, 2004 | 10:30 AM
USDM 4G VTEC's Avatar
just dont put it on afterwards
defeats the whole purpose of the wideband
it will not read true air fuel readings
dont be cheap, get that to a muffler shop, have them weld u a bong for $25 and do it right
Old Apr 27, 2004 | 11:48 AM
blackeg's Avatar
Default Re: (USDM 4G VTEC)
could you punch out the cat and actually weld a bung and put the wideband in the now hollow cat?
Old Apr 27, 2004 | 12:14 PM
Joseph Davis's Avatar
Default Re: (blackeg)
Hollow cats **** flow, if you do anything to the cat drive a piece of straight pipe through it. *ABOVE ALL* remember the platinum/rhodium lined innards of a catalytic converter are toxic; heavy metal poisoning is cumulative. However much you take into your body never leaves and after you take in a certain amount you get sick. Wash the inside of the cat with water to keep down dust, wear a mask, and empty the contents into a bagt you can close and dispose of responsibly.
Always make sure the exhaust gas is not exposed to any catalyst material, it "leans" out the AFR readings, rendering them garbage.
Old Apr 27, 2004 | 12:46 PM
warwagon's Avatar
i just didnt want to weld a bung in, just the stock mani with the cat all built in...
Old Apr 27, 2004 | 03:53 PM
PHiZ's Avatar
Cat's have platinum in them, now THAT is stunna.
-PHiZ
Modified by PHiZ at 12:58 AM 4/28/2004
PowerLeg
Oct 17, 2008 09:01 PM
Boostage
Jul 1, 2005 11:20 AM
Krut
Jan 8, 2005 10:39 PM
vtec.dc2
Dec 14, 2004 09:17 AM
typesguy
Feb 23, 2004 11:09 AM
