afr readings
Old Apr 12, 2005 | 11:49 AM
infra's Avatar
Default afr readings
Im about to brake in my motor by using stock ecu and injectors.
im removing the wastegate spring so i dont get any load.
and now im thinking.. wouldnt that affect the afr readings on my wideband?
since the wastegate is open all the time.
what afr is normal for a b16a2 with stock ecu at idle?
Old Apr 12, 2005 | 11:53 AM
11psiTurboSI's Avatar
Default Re: afr readings (infra)
14.7:1
Old Apr 12, 2005 | 11:55 AM
SOHC_MShue's Avatar
yup as long as your o2 sensor is hooked up closed loop should get you around a 14.7:1 ratio at idle.
Old Apr 12, 2005 | 12:25 PM
infra's Avatar
ok as i thought between 14.5 and 15
what about wastegate without spring, will it affect my afr.
turbodailydan
Jul 30, 2009 05:13 AM
got wide
Oct 20, 2008 09:16 AM
SpoolnByYou
Feb 21, 2006 05:47 AM
vet_girl
Jan 15, 2004 04:36 PM
Nextelbuddy
Oct 13, 2003 08:14 PM
