AFC blue wire mod... readings????
I have my S-AFC blue wire connected to the Oxygen sensor and am getting readings of 9.1 volts at WOT and a fluctuating voltage and cruise. Is this correct for a D16Z6 turbo on 450's and AFC hack?? (7psi)
Can u post your O2 sensor readings at idle, part throttle, WOT etc
thanks
paul
thanks
paul
You must be mistaken, if your getting readings of 9.1v then you have the wires hooked up wrong. the stock o2 sensor is from 0 - .9v and the voltage moves all over the place anyways so you can't really tune using that. About the only thing that its good for is telling if your running really lean or really rich where you would have 0.000v at lean and 0.999v at full rich
Is it really that rich??? I was worried I wasnt getting enuff fuel, its always over 0.9V at WOT does that mean i can trim the fuel back a bit???
What kinda reading should i be looking at when at part throttle off boost and part throttle on boost???
Il put it on the dyno ASAP but I have no money at the moment so jsut wanna check for the time being!!
thanks
paul
thanks
paul
I did a google search and found info on the blue wire mod readings.
http://www.thedropshop.tv/vafc.htm
Mostly about the hack, but at bottom the QnA section says .90v is good for turbo with the blue wire mod.
LS-G
Jun 21, 2002 08:11 PM
