afc with 3bar map
Old Apr 13, 2005 | 05:00 PM
ramennoodles's Avatar
Default afc with 3bar map
anybody know the correct sensor setting on the apexi afc for a 3bar map. i'm not using it for tuning, just for its peak holding display, and would like it to be somewhat close to the actual pressure reading. I've tried a bunch of different setting can can't seem to get the boost side of map reading correct. any one know the correct numbers for in and out settings?
Old Apr 13, 2005 | 05:10 PM
Da K00l Aid Mayun's Avatar
Default Re: afc with 3bar map (ramennoodles)
Dunno, I would use the AVC-R, not the AFC
Old Apr 13, 2005 | 05:12 PM
s2kdre's Avatar
Default Re: afc with 3bar map (Da K00l Aid Mayun)
it wont work with the afc i was asking the same thing, you have to chip the ecu for uberdata or chrome if you wanna use the 3 bar, i just use the afc and a missing link and i can boost up to 15 psi without any cel.
Old Apr 13, 2005 | 05:13 PM
s2kdre's Avatar
Default Re: afc with 3bar map (jdmhonda)
the afc doesnt even have the setting on it for a 3 bar.
Old Apr 13, 2005 | 05:38 PM
Deluzional's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">i just use the afc and a missing link and i can boost up to 15 psi without any cel.</TD></TR></TABLE>
wow, id personally be scared to ever run that high of psi with just an afc. what kind of power are you making?
Old Apr 13, 2005 | 06:29 PM
Default Re: afc with 3bar map (Deluzional)
like I said, I'm not using it for tuning. just for it's holding display capability. I already had it installed and don't feel like removing it. I got the negative pressure side pretty close but the possitive pressure side is way off. factory setting was 6in and 6out. now I'm at 15in and 15out. my guess is it problably only supports maybe 2 or 2.5 bar max
Old Apr 13, 2005 | 07:55 PM
Old Apr 14, 2005 | 03:54 AM
DRAGLS's Avatar
14in 6 out
Old Apr 14, 2005 | 09:33 AM
Default Re: afc with 3bar map (DRAGLS)
cool, thanks
Old Apr 14, 2005 | 10:13 AM
s2kdre's Avatar
our ecu doesnt advance the timing like accords and preludes so at 10 psi you're still at 16deg
Old Apr 14, 2005 | 11:07 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">our ecu doesnt advance the timing like accords and preludes so at 10 psi you're still at 16deg</TD></TR></TABLE>
what does this have to do with what I'm asking, all I wanted to know was the sensor setting for a 3bar map. I don't give a **** about timing at 10psi or whatever it is your trying to tell me
Old Apr 14, 2005 | 11:14 AM
dustin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramennoodles &raquo;</TD></TR><TR><TD CLASS="quote"> I don't give a **** about timing at 10psi or whatever it is your trying to tell me</TD></TR></TABLE>
Wow, you're a real ******.
Old Apr 14, 2005 | 11:19 AM
mattssi's Avatar
Default Re: afc with 3bar map (dustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">
Wow, you're a real ******.</TD></TR></TABLE>
His reponse just didn't have anything to do with the question. But is was answered.
Old Apr 14, 2005 | 11:21 AM
dustin's Avatar
Default Re: afc with 3bar map (mattssi)
With so many people that don't even try to offer useful advice at all... I don't understand the harsh response. Pretty sure he was just referring to the relative "safety" of the AFC hack at high boost... which is pefectly suited to the conversation at hand.
Old Apr 14, 2005 | 11:52 AM
my bad, sorry dude. If you read my post it said "I'm not using afc for tuning" I should have probly said that I wasn't using the afc "hack" either. my bad
Old Apr 14, 2005 | 11:57 AM
dustin's Avatar
it's cool. group hug.
ashb82
Engine Management and Tuning
Sep 3, 2009 03:29 AM
gsrt2c
Jun 8, 2003 05:35 AM
DS1
Oct 16, 2002 04:51 PM
Boostless97Lude
Sep 6, 2002 02:11 PM
KoRE
Sep 3, 2002 10:05 PM
