AEM tru boost
Old Jul 15, 2015 | 01:02 AM
yungkhmer's Avatar
Default AEM tru boost
My turbo does not have a pressure source nipple. how would i go about plumping the vacuum lines on my AEM try boost mac solenoid?
external wastegate
semi built ls turbo
http://aemelectronics.com/files/inst...er%20Gauge.pdf
i just found this, should i buy it?
http://www.atpturbo.com/mm5/merchant...egory_Code=BCS
Last edited by yungkhmer; Jul 15, 2015 at 01:46 AM. Reason: forgot to add something
Old Jul 15, 2015 | 03:49 AM
TheShodan's Avatar
Moderator
Default Re: AEM tru boost
Intake manifold and wastegate should be reference points..
Old Jul 16, 2015 | 03:54 PM
yungkhmer's Avatar
okay so in figure 7, since i don't have a nipple source on my turbo i should get the vacuum off the manifold?
figure 7 is about mid way.
Old Jul 16, 2015 | 06:27 PM
TheShodan's Avatar
Moderator
Intake manifold.. yes
Old Jul 17, 2015 | 06:49 AM
GT500FTW's Avatar
I just drilled into the side of my turbo and fitted nipple.
Old Jul 17, 2015 | 07:43 AM
TheShodan's Avatar
Moderator
some do that. In my experience, especially when using a very efficient airflow wheel, the compressor nipple is actually too strong of a reference point that causes boost creep issues when the tuner is using the solenoid to target wastegate spring boost levels.
I've never used the compressor housing (even if nipple is available, I plug it up).
But there has been a whole contorted debate about the whole thing I refuse to into because of its redundancy.
jetspeedz
Aug 23, 2009 02:21 PM
ctr83
Mar 21, 2008 02:41 PM
FastCougar
Nov 6, 2007 11:52 AM
GOIN V8 HUNTIN
Dec 12, 2006 05:17 PM
jdmtegxsi
Jan 23, 2003 08:23 PM
