AEM program specs
Old Aug 12, 2002 | 04:58 AM
revhardsi's Avatar
Default AEM program specs
Anyone here run an AEM on a 1.8L vtec motor with a turbo setup?? My AEM stand alone should be here shortly and I was wondering if anyone has some good settings I can use before I take it to the dyno for a complete tune.
Old Aug 12, 2002 | 08:00 AM
dbman96's Avatar
New User
Default Re: AEM program specs (revhardsi)
How much boost, what kind of injectors? Stock block / internals? Need more info.
The base maps from AEM's site are probably the best way to get started though.
Old Aug 12, 2002 | 11:34 AM
revhardsi's Avatar
Default Re: AEM program specs (dbman96)
1.8l JG pro series, race port b16a head, ITR cams, ITR intake, JG 65 MM TB, drag gen III, 255lph FP, no exhaust..just downpipe dump, maybe 550 cc or I might have to step up to 650cc running anywhere from 15 to 20 psi.
Any help would be appreciated!
Old Aug 12, 2002 | 12:34 PM
Evil DOHC's Avatar
Use 720's with a resistor pack. AEM is some good ****. DRT got it on their twin turbo civic, works like a charm. Use the stock harness, etc. Very user friendly from what I have seen.
EVIL
Old Aug 12, 2002 | 01:47 PM
revhardsi's Avatar
Default Re: AEM program specs (Evil GS-R)
I just might have DRT tune my car. Although, I'm not quite sure I nead that big of an injector...is this somewhat of the setup u personally run? I already have the resister box because I was running DSM 450's in it previously with the 1.6L.
Old Aug 12, 2002 | 09:47 PM
1fstevo's Avatar
New User
720cc here w/ems system on B18C1. Everything works great.
Old Aug 26, 2002 | 09:58 PM
justagsr's Avatar
Default Re: AEM program specs ([Evo]Hybrid)
Would you happen to have that base map or your map to help others out?
I have everything just putting the motor back in and I want to make sure I have a good base map. I checked the site and some are either running type r (b18c5) or b16 base maps.
Drop me a line at: mlself@csg.net
tia,
michael
cibao2ner
Sep 28, 2010 09:22 AM
TypeR0186
Aug 4, 2004 10:19 AM
ITRSpeed
Mar 15, 2004 07:43 PM
Ramocheese
May 18, 2002 12:59 PM
