AEM EMS, What else do i need???
Old Jan 27, 2003 | 01:27 PM
  #26
Joseph Davis's Avatar
Default Re: AEM EMS, What else do i need??? (LJR-LUDE01)
The AEM MAP sensors are accurate within 0.5%. If you look in a GM shop manual you will see that GM specifies a 5% deviance in there (Delco) MAP sensors. This is why the 3 Bar GM sensors range anywhere from 28-33psig.
I love it when basic shizz jumps up and bites me in the butt. I'll stfu and go away now...
  #27
quick108's Avatar
Is this like a require when you get ems to get a new map sensor..? everyday i end up buying more and more sutff for this kit this hobby is mad expensive ....
No, the Honda MAP sensor is good for ~12 psig. However, if you want to run more boost, you will need a different MAP sensor. The Delco (GM) will work fine. However, if you are ****, the AEM sensor is superior but is roughly $50 more.
[Modified by quick108, 2:34 PM 1/27/2003]
Old Jan 27, 2003 | 02:00 PM
  #28
Default Re: AEM EMS, What else do i need??? (quick108)
85-91 MAP = 9.25 psi max.
92+ MAP = 10.65 psi max.
Old Jan 27, 2003 | 02:05 PM
  #29
quick108's Avatar
Default Re: AEM EMS, What else do i need??? (J. Davis)
Where did you find this information?
Old Jan 27, 2003 | 04:30 PM
  #30
1fstevo's Avatar
New User
AEM map sensor looks bling bling but does it perform bling bling as well?
I almost bought one until I saw the price tag so I'll wait alittle until I seriously find the GM unit annoying then I'll change it. I found that let's say I am pushing 15 Pound on the dot, the EMS fuel map is using 12 Pound cell for fueling. So pretty much I have a 12 pound fuel cell that is tuned to be a 15 pound fuel cell.
Old Jan 27, 2003 | 05:30 PM
  #31
Most of the MAP sensor info I acquired through sifting a couple thousand DIY-EFI mailing list posts via their archives at www.diy-efi.org. I was looking for speed density theory and tech in order to redo my ignition map to include boost retard with AFC boost hacks.
I was ranting to USDM_ED9/Dropshop about how Doug @ Hondata gets 11.3 psi as the max range of the stock MAP where I was getting 11.8 psi, and how my math was correct, when he schooled me. If you use your AFC as a boost gauge, you get a max reading of +0.65 kg/cm^2 (9.25 psi) with the 85-91 MAP and a max of +0.75 kg/cm^2 (10.65 psi) with the 92+ MAP.
I went and verified with a couple different MAP sensors I have, and a Mityvac. I hooked the MAP sensors up to a spare computer PS's +5 signal, and applied "boost." 85-91 sensors peak at ~4.5 volts which is at or about where 9.25 psi should be, and 92+ (well, the 94 LS sensor I had) peaked at ~4.8 volts, which is 10.65 psi.
Pretty crazy shizz, huh?
Old Jan 27, 2003 | 05:38 PM
  #32
J2turbo21's Avatar
Default Re: AEM EMS, What else do i need??? ([Evo]Hybrid)
Sorry i dont understand this.So its is like this.Your boosting 15psi,the ems map is tuned for 12psi of boost.So you have a 12psi base map and your running 15psi?What makes that possible?Sorry im new the the ems.
Old Jan 27, 2003 | 06:43 PM
  #33
1fstevo's Avatar
New User
Default Re: AEM EMS, What else do i need??? (J2turbo21)
I have a 19 pound map but I usually push at 15 pound on the street. When I hit 15 pound on my boost gauge ( greddy ), EMS is using the cell (12psi, XXXX rpm) for fueling. It really doesn't matter since I have already tuned the maps to the a/f I wanted at every parameter disregard what ems is showing.
OMG, it's getting too complicated. Bottom line, I worked around the incorrect value and made it correct.
I used FJO monitor to tune my WOT since ems a/f parameter value is alittle off compared to the fjo. Since fjo comes preprogrammed, I trust fjo more than ems.
One wideband O2. Two unit is reading it. Two different values. Which one would you believe? FJO monitor or the EMS.
[Modified by [Evo]Hybrid, 3:46 AM 1/28/2003]
Old Jan 27, 2003 | 09:51 PM
  #34
quick108's Avatar
What is the differential? Remember, you can scale the voltage gain multiplier for the O2 sensors in the AEMPro software (O2#1 Gain).
Old Jan 27, 2003 | 10:14 PM
  #35
1fstevo's Avatar
New User
Tried but it's off like less than .5 and it varies across ranges. At certain a/f, it perfect, at other a/f, it's off. The gain mulitplier can only adjust the entire range. I certain the scaling is off but I used the closest scaling provided by a supra ems owner. Everyone is currently using that one. Many will agree that it's not aligned perfectly. So I rather trust my FJO monitor.
Old Jan 27, 2003 | 10:23 PM
  #36
1fstevo's Avatar
New User
http://www.aempower.com/bbs/viewtopi...1299&highlight=
This the thread telling you the new FJO caliberation.
Old Jan 28, 2003 | 08:42 AM
  #37
quick108's Avatar
You can tweak the AFR#1 Table in AEMPro to correspond with the FJO Display.
Old Jan 28, 2003 | 01:55 PM
  #38
1fstevo's Avatar
New User
Then it gets really complicated on testing and testing and testing. Need to make a potentiometer corresponse to 5 volt switchable than test the difference between the fjo data vs. ems data. I'm no electronic wizard so I don't even know how to assemble a correct potentiometer ( I had attemped to and failed at radioshack).
Old Jan 28, 2003 | 03:24 PM
  #39
quick108's Avatar
No no no...just take a voltmeter to the O2 signal input and change the O2#1 Gain until the Oxygen Raw #1 parameter correlates with the voltmeter reading. Then tweak the AFR#1 Table if needed.
[Modified by quick108, 4:24 PM 1/28/2003]
Boosteddb8
Jun 12, 2007 03:24 PM
int3gra
Jul 4, 2003 11:49 AM
R THIS
Jun 27, 2003 09:41 AM
qwklude82
Jan 14, 2003 12:07 PM
qwklude82
Jan 8, 2003 09:43 PM
