AEM EMS user...can you use 1 02 instead of 2? (00 gsr)
Old 05-12-2003, 11:49 AM
SpeedMonkeyRacing's Avatar
Default AEM EMS user...can you use 1 02 instead of 2? (00 gsr)
I'm thinking about taking out my 2nd o2 to replace it w/ my TE wideband sensor. However, I dunno if AEM EMS eliminates the 2nd o2 or I have to weld another bung just for the 5 wire o2..
Jeff-
Old 05-12-2003, 12:35 PM
New User
echo999's Avatar
Default Re: AEM EMS user...can you use 1 02 instead of 2? (Corporal-Jeff)
You don't need any of the stock O2 sensors to run AEM EMS..
If you install a wideband, put it in the stock O2 sensor bung #1... you want
a reading before your catalytic. From the output of your WB O2 controller,
you need to tap into the #1 o2 sensor pin in the harness to the EMS. You should
also provide the ground.. some people do this, some don't..
Old 05-12-2003, 12:41 PM
Default Re: AEM EMS user...can you use 1 02 instead of 2? (echo999)
damn..so my o2 is just there for looks huh?
Jeff-
b18psi
10-27-2006 01:09 PM
turboHX
08-03-2005 12:38 PM
11psiTurboSI
05-24-2005 02:22 PM
underpressure02
03-06-2003 08:32 AM
tegtyper
09-03-2002 04:33 PM
Quick Reply: AEM EMS user...can you use 1 02 instead of 2? (00 gsr)
