AEM EMS W/ AEM UEGO WB "Do I still need the stock primary O2 hook up?"
I have a 00 Civic SI turbo with the AEM EMS and AEM UEGO and I unhooked the stock primary O2 sensor and all I have for sensors is the one AEM UEGO sensor with O2 feedback on... I don't have to have my primary stock O2 sensor hook up anymore correct?
Re: AEM EMS W/ AEM UEGO WB "Do I still need the stock primary O2 hook up?" (2000civicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000civicsi »</TD></TR><TR><TD CLASS="quote">yes that correct</TD></TR></TABLE>
Thanks... So if I didn't have the WB would I still need it hook up?
Re: AEM EMS W/ AEM UEGO WB "Do I still need the stock primary O2 hook up?" (11psiTurboSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11psiTurboSI »</TD></TR><TR><TD CLASS="quote">bump for an answer...</TD></TR></TABLE>
You dont need an o2 sensor at all with the AEM EMS.. If you have a narrow or wideband then you can use o2 feedback, if you didnt have one at all then you couldnt use o2 feedback..
Re: AEM EMS W/ AEM UEGO WB "Do I still need the stock primary O2 hook up?" (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves »</TD></TR><TR><TD CLASS="quote">
If you have a narrow then you can use o2 feedback</TD></TR></TABLE>
Thanks guys...How would that work^?
Re: AEM EMS W/ AEM UEGO WB "Do I still need the stock primary O2 hook up?" (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">Disable O2 feedback. Runs strickly off the maps.</TD></TR></TABLE>
good info in this thread. i was too wondering about this..
Re: AEM EMS W/ AEM UEGO WB "Do I still need the stock primary O2 hook up?" (scoop)
If you have the Uego sensor, use the closed loop o2 feedback, it is a great tool, and you can use the internal datalogging to datalog with o2 feedback, and without o2 feedback, overlay them, and see how much % change the computer made to get to your target vaule, and then change those areas in your map by that much inorder to get your air/fuel perfect.
11psiTurboSI
09-26-2006 09:53 PM
SpeedMonkeyRacing
05-12-2003 12:41 PM
