AEM EMS quesion
Old Oct 6, 2005 | 03:35 PM
firstclassjdm's Avatar
Default AEM EMS quesion
00 ITR. If you look at my sig, you'll see my set up. I'm thinking about not using the secondary O2 sensor. I'm gonna run a test pipe connecting my DP and exhaust. I'm gonna put a bung at the beginning of the pipe for the primary o2 and put a bung in my DP at the end for my AEM wide band. When starting up the EMS for the first time, will it throw a code for missing secondary? Does anyone have a better idea? Thanks.
Old Oct 6, 2005 | 03:39 PM
ORcivicsi's Avatar
Default Re: AEM EMS quesion (firstclassjdm)
With AEM you can cancle the secondary O2 sensor
Old Oct 6, 2005 | 03:57 PM
Default Re: AEM EMS quesion (ORcivicsi)
do i need to program it at initial start or will it know itself?
Old Oct 6, 2005 | 04:38 PM
Jared's Avatar
The AEM doesn't "set codes" per say. It will not read off the second o2 on a Honda unless you tell it to. It uses the primary o2 input for o2 feedback.
Old Oct 6, 2005 | 10:10 PM
yee SERIOUS's Avatar
i think the aem forum has a thread on how to do a close and open o2 feedback. is that what he needs to setup jared? a closed o2 setup?
Old Oct 7, 2005 | 07:55 AM
blaze the chemi's Avatar
Default Re: (undercoverdc2)
The secondary O2 sensor is an OBD2 component. The AEM EMS is OBD1. Therefore it won't throw the code. I wish however that the AEM EMS could be OBD2 so I don't have to change so much crap to pass emissions here in ATL, GA area.
Old Oct 9, 2005 | 05:21 PM
Default Re: (blaze the chemi)
Thanks guys. i have a better idea now. I'll try it out and see. Thanks again
Old Oct 10, 2005 | 10:27 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaze the chemi &raquo;</TD></TR><TR><TD CLASS="quote">The secondary O2 sensor is an OBD2 component. The AEM EMS is OBD1. Therefore it won't throw the code. I wish however that the AEM EMS could be OBD2 so I don't have to change so much crap to pass emissions here in ATL, GA area.</TD></TR></TABLE>
there is ems available for obd2a and obd2b. but just because it's obd2 compliant does not mean that you'll still pass emissions.
the secondary o2 sensor is only used to check on the cat. the ecu compares the reading between the primary and secondary. i think it's when the ecu reads they're the same then you get a CEL. which is one i have right now. it sucks throws the car into limp mode.
h22_crx
Nov 14, 2006 08:07 AM
b18psi
Oct 27, 2006 01:09 PM
11psiTurboSI
May 24, 2005 02:22 PM
SpeedMonkeyRacing
May 12, 2003 12:41 PM
underpressure02
Mar 6, 2003 08:32 AM
