AEM EMS help (TPS, MAP and Injector problems)
Old Feb 11, 2007 | 09:01 AM
  #26
stinker504's Avatar
I went through it and made sure that:
- "MAP Analog Input" was set to MAP Voltage
- "Throttle Analog Input" was set to TPS Voltage
That made no change. I'm still getting 7 volts out of all three wires going to the sensors. Now I'm getting a little worried that the EMS may have damaged the sensors by sending out crazy voltages. I guess I'll tackle that issue once the EMS gets worked out.
Thanks for the help so far! Keep the suggestions coming.
Old Feb 11, 2007 | 09:02 AM
  #27
stinker504's Avatar
If I can find a 1050 box I'll try that.
Old Feb 11, 2007 | 03:29 PM
  #28
alpha's Avatar
Default Re: (stinker504)
I have had problems in the past with the older 30-1010's and 30-1000's. Not saying the box is your problem but putting it out there
Old Feb 11, 2007 | 04:41 PM
  #29
stinker504's Avatar
I'll give AEM a call tomorrow. Hopefully they have an idea.
  #30
wHOAlly's Avatar
Default Re: (alpha)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alpha &raquo;</TD></TR><TR><TD CLASS="quote">I have had problems in the past with the older 30-1010's and 30-1000's. Not saying the box is your problem but putting it out there</TD></TR></TABLE>
the prob with the older boxes, is that people are buyin them used, and they exchange alot of hands, not knowing what the previous owner did to the box....custom mods, damage, etc etc
Old Feb 11, 2007 | 05:28 PM
  #31
stinker504's Avatar
Hopefully it doens't come down to me buying a new unit.
Right now I'm worried that I have to replace sensors that the EMS may have damaged. But I'll worry about that when the EMS starts acting correctly.
Old Feb 11, 2007 | 09:45 PM
  #32
GodFather of Boost's Avatar
does the map signal move when the throttle is depressed? If so go over your wiring carefully there is a ground problem.
Old Feb 12, 2007 | 05:46 AM
  #33
stinker504's Avatar
The signal does not move with the throttle movement. Everything works as normal with the factory ECU. Once the EMS is plugged in the Ground acts up. I have to wait for the West coast to wake up and we'll see what AEM has to say.
Old Feb 12, 2007 | 09:37 AM
  #34
TrueNorthStar's Avatar
I had similar with my 1040. It showed 100% on tps and map. Long story short, I took the EMS to AEM and had them check it out.
They gave it back to me and said that it worked fine on their test bench and it should be fine. I took the guy out to the parking lot and plugged it into my civic w/laptop and it had the same problem. I then plugged in the stock ecu and it worked fine.
He took the ems back into the repair center and swapped out the daughter board and gave it back to me. Worked fine after that and I haven't had any probems since then.
I guess I'm lucky that I live that close to AEM, that would have sucked if I had to send it back and forth like that.
Old Feb 12, 2007 | 09:52 AM
  #35
stinker504's Avatar
I just spoke to AEM. Just like you they said the bench tested everything before sending it back to me. They recommened one more test that I'll try today before sending it back to them.
Old Feb 12, 2007 | 01:06 PM
  #36
kcevo's Avatar
I had this happen to me on a customers 30-1400 Mustang EMS...all three wires for the map sensor(power, ground, signal) all showed 5 volts with the AEM plugged in.
Had to send the box back as either the mother/daughter boards were fried.
Hope this isn't the case for you and that your's may still be under warranty, as they now have a very strict policy on repairs. $60 to look at the unit if out of warranty, plus the cost of the parts needing replaced.
Old Feb 12, 2007 | 05:03 PM
  #37
stinker504's Avatar
When that happened did any of the sensors get damanged? I'm worried about the sensors because I have 6 sensors getting voltage where there should have been a ground.
Old Feb 12, 2007 | 05:44 PM
  #38
stinker504's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kcevo &raquo;</TD></TR><TR><TD CLASS="quote">
Hope this isn't the case for you and that your's may still be under warranty, as they now have a very strict policy on repairs. $60 to look at the unit if out of warranty, plus the cost of the parts needing replaced.</TD></TR></TABLE>
I don't have a problem with paying for repairs. I'm very happy with their tech support and I think it's well worth the money. As long as it's nothing ridiculous.
Old Feb 13, 2007 | 10:33 AM
  #39
kcevo's Avatar
None of the sensors were damaged.
Plugged the repaired box back in and everythig was back up and running like normal.
Old Feb 13, 2007 | 06:33 PM
  #40
stinker504's Avatar
That's good news from you. I'll ship the box out tomorrow. I haven't had a chance to get to UPS.
Old Feb 13, 2007 | 08:23 PM
  #41
nfn15037's Avatar
I've had this same problem with an SR20 box. Sent it to AEM and they said it was fine. It magically worked when we got it back, with zero changes to anything. They must know there is some issue here, since they love to charge for anything and everything.
I think my wastegate hose fell off
Old May 29, 2007 | 09:08 AM
  #42
Lonnie's Avatar
Default Re: (nfn15037)
Bump my boy is having the same problem with his 1010 box. What was the outcome.
My_EFsedan
Oct 18, 2011 09:50 PM
magefa
Engine Management and Tuning
Apr 8, 2009 06:26 AM
ORcivicsi
Jul 12, 2005 01:48 PM
hovic
Sep 28, 2004 01:25 PM
Brian_92GSR
Nov 3, 2002 05:28 PM
