AEM EMS help...
Old Mar 10, 2003 | 01:45 PM
LJR-LUDE01's Avatar
Default AEM EMS help...
well I finish my turbo install... and try to turn on the car.... =***( no luck... I swap out the ems to my original ecu nothing.... I try to turn on the car and is just whines...
this is what i got on....
Walbro intake fuel pump
450 dsm injectors
resistor box
t3/t60-1
1020 aem ems with quaaludes calibration.. for his turbo lude with 440's
max-rev manifold
max-rev dp
max-rev i/c
35mm tial wastegate
hks bov
gm boost solenoid
boost guage
I know is kind of a general question... but can you guys just give some ideas as to what I can check to get my car to start...
Old Mar 10, 2003 | 01:58 PM
Universal Magnetic's Avatar
Default Re: AEM EMS help... (LJR-LUDE01)
Hmmm...
1. Is the stock ecu or aem ecu getting power?
2. Does the starter turn?
3. I would re connect the stock ecu and get the car running with that first.
4 Triple check your wiring for your DSM 450's
5. Do you have spark?
Old Mar 10, 2003 | 01:59 PM
echo999's Avatar
New User
what does it do exactly when you crank it with the EMS in it?
One thing to definitely do AFTER you load the calibration files is to turn the car fully
OFF, and then crank it. I've had problems with the upload calibration not taking effect until I do a "cold boot"
[Modified by echo999, 11:03 PM 3/10/2003]
Old Mar 10, 2003 | 02:00 PM
Hmmm...
6. Make sure spark plug wires are in the correct order and plugs aren't fouled
7. Does the Fuel pump cycle on/off when Key On/ Engine Off?
hope this helps
Old Mar 10, 2003 | 02:14 PM
LJR-LUDE01's Avatar
Default Re: AEM EMS help... (@ntiRice)
well I know is not the ems now since i re-install the stock ecu and I get the same prob... I will double check my injectors wiring again to make I did it right
edit: just check the fuel pump and i can hear the whining noise so it works..
[Modified by LJR-LUDE01, 6:21 PM 3/10/2003]
Old Mar 10, 2003 | 02:21 PM
Mase's Avatar
I dont think you are going to be able to start the car w/ those big injectors w/ the stock ECU
get your multimeter out and start checking the wiring of the injectors.....start there....
Old Mar 10, 2003 | 02:22 PM
LJR-LUDE01's Avatar
Default Re: AEM EMS help... (Mase)
yes that's what I'm doing next... thank... and I check the fuel pump and is working
what do i look on the spark plugs side? to see if I'm getting a spark
[Modified by LJR-LUDE01, 6:23 PM 3/10/2003]
Old Mar 10, 2003 | 02:24 PM
GZERO's Avatar
i don't know if you know or not, but did you load your cars base map onto the EMS??
if you did, just disregard, also, try cranking the car with the EMS and try to hear the injectors working before checking the wiring, that way you will know for sure if is the injectors
EDIT: about the spark plug, just take the spark plug out, connect it to the spark plug cable and try to touch ground and tell someone to crank the car, you should see sparks from the spark plug (DUH! )
check each one
[Modified by GZERO, 6:27 PM 3/10/2003]
Old Mar 10, 2003 | 02:57 PM
prophet's Avatar
stock ecu WILL start them up just not idle right, run right or do anythign else right .... sounds like either no fuel or no spark.
Old Mar 10, 2003 | 03:02 PM
LJR-LUDE01's Avatar
Default Re: AEM EMS help... (prophet)
well I didn't load a base map i loaded some's else that has a similar base cal...
i'll post pic in a sec of my injector wiring see if you guys see something wrong I don;t see
Old Mar 10, 2003 | 03:19 PM
LJR-LUDE01's Avatar
here's pic of one of my injector clip...
you can see my resistor box in the top right corner and how is connected
[Modified by LJR-LUDE01, 7:21 PM 3/10/2003]
Old Mar 10, 2003 | 03:31 PM
Quaalude's Avatar
Did you follow AEM's instructions and upload the v0.94 firmware before you uploaded the calibration map? Are you getting spark? Try pulling one spark plug wire off and stick a spark plug on there and ground it to see if you get a spark. If you have spark, then it sounds like a fuel problem. Double check your wiring of the resistor box and injector clips. What is your email address? I'll send you my latest map with some options changed since I'm using different features.
Old Mar 10, 2003 | 03:55 PM
LJR-LUDE01's Avatar
Default Re: AEM EMS help... (Quaalude)
Is too dark out side... so I have to wait until tomorrow to continue to check for prob.. i did load the new firmware before i load your map... so I doubt that's the prob... I will re-do the wiring tomorrow just to double check since my brother did that part....
Old Mar 10, 2003 | 03:59 PM
boostedsol's Avatar
When I tried to start my sol w/ the aem ems, it wouldnt turn over. I then later found out that on the 30-1000 system if there was a wire in pin A25, no spark would occur w/ the aem ems. I then removed that pin altogether, and she started right up.
Go to http://www.aempower.com and PM JP in the ems forum. He has helped me numerous times, and is also an engineer for the ems. I'd check and see what he has to say about it.
Old Mar 10, 2003 | 04:01 PM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
My car started up just fine with 450cc DSM injectors and a stock ECU.
I think the wiring is the problem.
[Modified by newt2, 5:01 PM 3/10/2003]
Old Mar 10, 2003 | 04:40 PM
BoostedSi's Avatar
Default Re: AEM EMS help... (newt2)
You probably had an safc/vafc or some type of fuel control. 450s will not idle on a stock ecu
Old Mar 10, 2003 | 05:04 PM
prophet's Avatar
Default Re: AEM EMS help... (BoostedSi)
u still can start your car...
Old Mar 10, 2003 | 07:55 PM
LJR-LUDE01's Avatar
nope i gave up for tonight... is going to be an early day for me tomorrow... i'll go buy new rc injectors tomorrow if necesary... just in case since the dsm i got were used....
Old Mar 10, 2003 | 07:59 PM
Tinker219's Avatar
check the wiring before you go blow another $300...if you have the money burning a hole in your wallet, My PayPal id is Tinker219@hotmail.com
Old Mar 10, 2003 | 08:10 PM
LJR-LUDE01's Avatar
Default Re: AEM EMS help... (Tinker219)
lol... for my car... my wallet is no prob.... but I will re-check and re-do my wiring tomorrow befoer i get new injectors.... hopefully that's the prob...
this is how I install one of the injector clip and the resistor box.... the other three injectors my brother did...
my stock injectors clips had two wire coming out....
Blue/yellow with black stripe
Red/yelow with black stripe
Brown/yellow with black stripe
Yellow/yellow with black stripe
I cut all the yellow with black stripe wiresand connected them to the resistor box than I ran one wire out of the resistor box to the the four yellow with black stripe
wires. the solid color wires I didn't touch.
[Modified by LJR-LUDE01, 12:17 AM 3/11/2003]
Old Mar 10, 2003 | 09:39 PM
LJR-LUDE01's Avatar
I found thi diagram and this is how I did my wiring...
bottom diagram
Old Mar 10, 2003 | 09:41 PM
Mase's Avatar
did you check to make sure you are getting spark?
Old Mar 10, 2003 | 09:51 PM
LJR-LUDE01's Avatar
nope i try to get my wife to help me so she can crank the car and i can check the spark but she all mad plus it got to dark... my brother is coming tomorrow to help me out hopefully I can fix it what ever it is... oh and thanks for the call ...
[Modified by LJR-LUDE01, 1:52 AM 3/11/2003]
Old Mar 10, 2003 | 10:30 PM
Hondata's Avatar
Glad to see that Hondata's technical diagrams could be of some help.
Old Mar 10, 2003 | 10:32 PM
Mase's Avatar
Default Re: AEM EMS help... (Hondata)
