AEM EMS boost control function
Old Aug 19, 2002 | 05:36 PM
1's Avatar
Default AEM EMS boost control function
Can this be hooked up to control boost by itself or does it work in conjuction with an EVC?
TIA
Old Aug 19, 2002 | 05:51 PM
turbologist's Avatar
Default Re: AEM EMS boost control function (1)
I believe that its supposed to control boost by itself. I hear that alot of people use an external boost controller b/c its easier to tune. You can set the boost at 0 all the way across and then set ur EVC accordingly for the desired boost. Then just tune ur EMS for the correct a/f, timing, etc. I think that it would be better to learn to tune the boost via the EMS b/c it is a feature that u payed for and in the long run it will help u be a better tuner and quite possibly in turn have ur car run alot better.
Old Aug 19, 2002 | 06:01 PM
00TurboEX's Avatar
Default Re: AEM EMS boost control function (drealboostedhybrid)
in order to use the boost control function, you have to buy a GM Boost Solenoid. i cant remember the part #, but if you go on the aem message boards its on there somewhere.
david
Old Aug 19, 2002 | 06:20 PM
b18cya's Avatar
Default Re: AEM EMS boost control function (00TurboEX)
also, can an output of the EMS be hooked up to a display (like an LCD screen) to show realtime maps of various inputs it's recieving?
like maving it display the current a/f ratio, boost level, or something like that?
Old Aug 19, 2002 | 06:21 PM
b18cya's Avatar
Default Re: AEM EMS boost control function (b18cya)
i dunno if you understood that, but i'm buying a used turbo kit & eventually i'll get the EMS for some fine tuning. & i just wanted to know if it is capable of that
Old Aug 19, 2002 | 06:50 PM
bmm89's Avatar
yes, datalog, and gm controller is a whopping $8, i may gave with it in the future
The Jacko
Jul 31, 2006 06:12 AM
sander
May 18, 2006 12:56 AM
BodyKits NW
Aug 12, 2005 01:57 PM
Spoold_R
Apr 16, 2003 04:25 PM
PyroVTEC
Jun 7, 2002 11:51 AM
