AEM EMS!!!!!!!
Old Apr 11, 2006 | 07:06 PM
richeybrooks's Avatar
Default AEM EMS!!!!!!!
im trying to get some work done on my timing maps and wondering if anyone had tuned cals or knock logs?
AIM: somer14
Old Apr 11, 2006 | 07:27 PM
Adriano's Avatar
Default Re: AEM EMS!!!!!!! (richeybrooks)
Go to aempower.com and check out their tech forum. They are very useful.
Adriano
Old Apr 11, 2006 | 08:02 PM
Default Re: AEM EMS!!!!!!! (Adriano)
they just changed there form so all the files/logs that were up are gone.
not looking to be told where to go just files and logs
Old Apr 11, 2006 | 08:12 PM
mrbsponge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richeybrooks &raquo;</TD></TR><TR><TD CLASS="quote">they just changed there form so all the files/logs that were up are gone.
not looking to be told where to go just files and logs</TD></TR></TABLE>
not too many people are just gonna hand over a log, or cal file. especially with an answer like that.
you get more bees with honey, than with ****
why cant you just alter your timing maps?
Old Apr 11, 2006 | 09:01 PM
Default Re: AEM EMS!!!!!!! (mrbsponge)
i was not trying to be rude at all. my bad, a lot mroe honda guys will see this form rather than aem's
Im having trouble telling the difference between noise and knock. maybe some of you could look at my logs. what is noise usually under in low rpm im getting rather large spikes 1.xx Volts with a bunch of timming pulled at no or very low loads.
i know i know next time ill post an internal log
but let me know what you guys think
Old Apr 11, 2006 | 09:28 PM
Muckman's Avatar
Moderator in Chief
To do a baseline knock pull run conservative timing (base map/stock) at lowest boost or NA. Do a pull in a low gear, maybe 2nd or 3rd at low throttle, maybe 25% and hold it steady to redline. Under these conditions real knock should not occur and the knock inputs you recorded should be engine noise. This should allow you to modify your knock filter against a known constant. However I found the base maps filter was very accurate as is.
Old Apr 11, 2006 | 10:12 PM
Default Re: AEM EMS!!!!!!! (Muckman)
ill do that tommrow and post new logs.
ill also recalberate the knock table like i had been planing to do
integlspwr2k
May 13, 2005 08:04 AM
sol_1320
12
May 7, 2005 10:09 PM
program
Jul 12, 2004 08:48 PM
Soon_2b_evil
May 28, 2004 10:59 AM
NyQuiL
Apr 29, 2004 09:35 AM
