aem 1020 help
Old May 14, 2006 | 11:47 AM
  #26
vtekthis's Avatar
Default Re: aem 1020 help (vaporboy12)
the cal. you trying to use must not be ver1.19, if you pc and ecu are now both 1.19, you cant use the 1.11 cals or any other cals for the 1.19.
you may have to convert that cal if its in 1.19 form
Old May 14, 2006 | 11:50 AM
  #27
alpha's Avatar
Default Re: aem 1020 help (vtekthis)
I'm sure he is using a 1.19 cal. I told him where the startup calibrations are. It sounds like he is having a connection problem; serial to usb adapter. Will see.
Old May 14, 2006 | 11:53 AM
  #28
vtekthis's Avatar
Default Re: aem 1020 help (0x64)
ahhhhhhh one of those hehe, they suck, especially the belkins
Old May 14, 2006 | 11:57 AM
  #29
vaporboy12's Avatar
no im using a serial on com 1 its selected and i used a map in the start up maps that in the aem software from there site
Old May 14, 2006 | 12:24 PM
  #30
alpha's Avatar
Hmmm ... You tried a couple times? Let me go get some screen shots.
Old May 14, 2006 | 12:59 PM
  #31
alpha's Avatar
Make sure you don't have an older version of AEMPro or AEM Pro files installed on your computer.
How-to upgrade your AEM EMS firmware to 1.19:
Open AEMPro.exe. The following screen will pop-up. Select the corresponding port.
Once you have done that goto the "ECU" tab then down to "Update EMS firmware..." shown below.
The screen below will pop-up. Click "Next>" twice to select the 1.19 firmware.
Select "AEM15 v1.19b.FIN" and click "Open" .
Click "Next>" again to select the calibration. If you dont have a calibration start with the proper startup calibration. In my case 1040 Turbo 440.V1.19.cal . This is just a startup calibration. Dont expect to just upload it and start your car.
The following will pop-up next. Wait for it to finish.
After that the following will pop-up. Wait for it to finish.
Same as above.
Click "OK". Cycle the ignition twice.
Now go start tuning
Old May 14, 2006 | 01:58 PM
  #32
vaporboy12's Avatar
mine gets to the uploading calibration point as soon as i click the cal i want it says no installations for this ecu type or version
Old May 14, 2006 | 02:11 PM
  #33
alpha's Avatar
Default Re: (vaporboy12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 &raquo;</TD></TR><TR><TD CLASS="quote">mine gets to the uploading calibration point as soon as i click the cal i want it says no installations for this ecu type or version</TD></TR></TABLE>
The only times I have seen that were when the serial to usb cable was bad and another version of AEMPro was still on the computer. Try uninstalling 1.19. After that search the Windows directory for "aem". If a DLL file comes up with aem in the name, I forget the specific file name, delete it and reinstall 1.19.
Old May 14, 2006 | 02:39 PM
  #34
vaporboy12's Avatar
Default Re: (0x64)
ok ill give it a try
Old May 14, 2006 | 03:12 PM
  #35
vaporboy12's Avatar
ok so i got 1.11 on it so now im goin to go from there thanks for the help guys
killacamcivic
Engine Management and Tuning
Jan 13, 2013 05:17 PM
Turbo-LS
Apr 28, 2005 08:24 AM
done
Dec 30, 2003 08:08 PM
civicvtec3
Nov 27, 2003 05:25 PM
GSRacer2102
Jan 5, 2002 09:55 AM
