aem 1020 help
Old May 13, 2006 | 03:35 PM
vaporboy12's Avatar
Default aem 1020 help
ok just picked up a 1020 ecu never used its got a .40 version on it and im trying to upgrade to 1.19 but its not letting me... can someone walk me threw the upgrade i already have a 1.19 base map im goin to use
Old May 13, 2006 | 04:50 PM
NJIN BUILDR's Avatar
Default Re: aem 1020 help (vaporboy12)
You can search the AEM Forum but I believe you can only update from .94 version with the firmware download.I think you need to change the chip in the box if you have a real old version.If you have a burner you can reburn it or call AEM and they can send you a new chip.
Old May 13, 2006 | 04:55 PM
vaporboy12's Avatar
Default Re: aem 1020 help (NJIN BUILDR)
ok
Old May 14, 2006 | 06:52 AM
vaporboy12's Avatar
anyone else?
Old May 14, 2006 | 08:06 AM
vtekthis's Avatar
do you have the 1.19 coversion on your PC? you need to install version 1.19 on you PC first then got to install ecu and find 1.19 and install the firmware
Old May 14, 2006 | 08:08 AM
vtekthis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">You can search the AEM Forum but I believe you can only update from .94 version with the firmware download.I think you need to change the chip in the box if you have a real old version.If you have a burner you can reburn it or call AEM and they can send you a new chip.</TD></TR></TABLE>
Or this
Even know ive never had to deal with this issue
Old May 14, 2006 | 08:17 AM
vaporboy12's Avatar
Default Re: aem 1020 help (vtekthis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekthis &raquo;</TD></TR><TR><TD CLASS="quote">do you have the 1.19 coversion on your PC? you need to install version 1.19 on you PC first then got to install ecu and find 1.19 and install the firmware</TD></TR></TABLE>
i tryed to install it like you said but when i connect to the ecu its say found no files for v0.40.. its not even install the firmware of the 1.19 thats on my computer
Old May 14, 2006 | 08:23 AM
vtekthis's Avatar
That means that the file (map) in the ecu is still version .40, you have to put version .40 on you PC to download the map......
or update the ecu's firmware, which is in the ecu drop down menu, but you will lose whatever file is already on the ecu...
hope that helps
Old May 14, 2006 | 08:27 AM
alpha's Avatar
What are you having problems with? Install the latest version of 1.19 on your laptop. Make sure you have the right port selected under "ECU -&gt; Connection Port/Ports". Next "ECU -&gt; Update EMS firmware". Go through that process and your set.
Old May 14, 2006 | 08:31 AM
vtekthis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekthis &raquo;</TD></TR><TR><TD CLASS="quote">That means that the file (map) in the ecu is still version .40, you have to put version .40 on you PC to download the map......
hope that helps</TD></TR></TABLE>
thats if you have ver1.19 on you PC already
Old May 14, 2006 | 08:37 AM
vaporboy12's Avatar
so i want to delet the 1.19 off the computer install the .40 pull the map off there... update to 1.19?
Old May 14, 2006 | 08:39 AM
vtekthis's Avatar
do you want the map on the ecu? or do you just wanna put in a base 1.19map?
If you have 1.19 on you PC already, and you dont car about the map on the ecu, just update the ecu's firmware
If you wanna keep the map thats on the ecu, you have to have ver .40 to on you PC to communicate to the ecu
Old May 14, 2006 | 08:42 AM
alpha's Avatar
thats if you have ver1.19 on you PC already</TD></TR></TABLE>
Easy enough to get it on there
Old May 14, 2006 | 08:45 AM
vtekthis's Avatar
Default Re: aem 1020 help (0x64)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">
Easy enough to get it on there </TD></TR></TABLE>
true
Old May 14, 2006 | 08:58 AM
alpha's Avatar
AEMPro 1.19, AEMLog and all Instructions
vaporboy12's Avatar
no i dont care about the map on there but when i try to update the firm where when it gets to the part where you pick a cal. file it doesnt let me and then the it exits out of the update
Old May 14, 2006 | 09:02 AM
alpha's Avatar
Double check that you have the right version of AEMPro on your laptop and you are selecting the right firmware and calibration files.
Old May 14, 2006 | 09:08 AM
vtekthis's Avatar
it comes up with the 1.19 cal file though?
vaporboy12's Avatar
ill check over everything. but i should be able to upgrade from .40 to 1.19 without sending it back to aem?
Old May 14, 2006 | 09:12 AM
alpha's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 &raquo;</TD></TR><TR><TD CLASS="quote">ill check over everything. but i should be able to upgrade from .40 to 1.19 without sending it back to aem?</TD></TR></TABLE>
No need to send the ECU back to them. You or your tuner can upgrade the firmware.
Old May 14, 2006 | 09:13 AM
alpha's Avatar
The AEMPro Startup Calibrations are under C:\Program Files\AEM\AEMPro\Startup Calibrations\Honda-Acura . The AEMPro Firmware files are under C:\Program Files\AEM\AEMPro\FIN Files .
Old May 14, 2006 | 09:17 AM
vaporboy12's Avatar
ok ill be home in a couple hours to give it a try....
Old May 14, 2006 | 09:18 AM
vaporboy12's Avatar
thanks for the help ill be back on in a few to need more help or hopefully say thank you for getiting this working for me
Old May 14, 2006 | 11:44 AM
vaporboy12's Avatar
ok heres what i did went to install ecu 1.19 then added it then verified.... went to update firmware... went threw that and got to the point were it said select cal. file so i tried to do the 1020 440 turbo basemap clicked open and it said no installations for this ecu type or version?
Old May 14, 2006 | 11:46 AM
alpha's Avatar
Cycle the ignition. Make sure you selected the right port for the laptop to connect to the AEM EMS. Sounds like you are using a Serial to USB adapter. When I first started using AEM EMS that's the problem I ran into. Try it a couple times.
