Advantages of LS Tranny?
Old Jun 24, 2003 | 03:33 PM
VanHonda's Avatar
Default Advantages of LS Tranny?
I have a friend with an NA LS/VTEC that will switch trannies with my flat out. I have a turbo Civic Si with forged rods and pistons. Is there any advantages to running the LS tranny pushing about 10 psi on the street or should I keep the stock Si Tranny? If I should switch, what should I look for to make sure its in good condition?
Thanks,
Craig
Old Jun 24, 2003 | 03:56 PM
mskibbz-T's Avatar
Default Re: Advantages of LS Tranny? (VanHonda)
You should not switch...
Old Jun 24, 2003 | 04:02 PM
EF9RacerWhoa!'s Avatar
Default Re: Advantages of LS Tranny? (mskibbz-T)
si tranny owns
Old Jun 24, 2003 | 04:05 PM
blackANESE's Avatar
Default Re: Advantages of LS Tranny? (EF9RacerWhoa!)
N/A Ls/vtec with LS tranny----sucks for him
Keep the SI tranny
Old Jun 24, 2003 | 06:03 PM
hawjdude's Avatar
Default Re: Advantages of LS Tranny? (blackANESE)
I thought that the ls tranny was one of the best tranny to use for boosted cars.
Old Jun 24, 2003 | 07:03 PM
Adriano's Avatar
Default Re: Advantages of LS Tranny? (hawjdude)
The only way the ls tranny will help is if you have a small turbo. I get full boost on my t3/t4 around 5200. If i put an ls tranny there, it would take for ever to hit full boost. Just keep your tranny.
Old Jun 24, 2003 | 07:17 PM
showoffb16's Avatar
i would go for ls with LSD! i have on and its good for turbo
Old Jun 24, 2003 | 07:18 PM
doughboy247's Avatar
if you do alot of highway racing then go for it...that's the only advantage. if you're strictly a 1/4 mile racer then stay with the b16. if it was me, i'll keep the b16
Old Jun 24, 2003 | 09:28 PM
hawjdude's Avatar
Default Re: Advantages of LS Tranny? (doughboy247)
So if i want to go for 1/4 racing than switch to si. I really need a new tranny. gsr tranny is messed up.
Old Jun 24, 2003 | 09:31 PM
liam821's Avatar
25 Year Member
Keep the SI tranny. The nice thing about the Si tranny is if you want longer gear ratios..you can just get a larger tire (ie slicks). (Its a little harder the other way around)
liam
itz_nij
Mar 15, 2004 05:26 PM
Billy_goat
Sep 21, 2003 01:40 PM
UltRaH22
May 18, 2003 02:49 PM
FOrSfEd
May 28, 2002 08:14 AM
