Adjusting Turbo Need help please
Old 04-17-2006, 02:33 PM
BoostedGreddy's Avatar
Default Adjusting Turbo Need help please
I just clocked my compressor to where i wanted it but not sure if doing the same to the oil mid-section would damage it? I see 4 bolts that are holding it down are those the only bolts?
My question is, Is it possible to adjust your oil feed/drain mid section?
AND
If there is any torque specs on these bolts what are they?
thanks guys in advance.
Old 04-17-2006, 05:44 PM
Default Re: Adjusting Turbo Need help please (BoostedGreddy)
any know?
Old 04-17-2006, 05:56 PM
GaRn's Avatar
Do a search on the torque specs, I have found it before..
You can rotate both the turbine housing and the compressor housing
Old 04-17-2006, 06:21 PM
Default Re: Adjusting Turbo Need help please (GaRn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GaRn &raquo;</TD></TR><TR><TD CLASS="quote">Do a search on the torque specs, I have found it before..
You can rotate both the turbine housing and the compressor housing </TD></TR></TABLE>
How'd you rotate the turbine housing? i unbolted all the screws and that sonofa BI**ch didnt move only the compressor side did ? or do i also have to un bolt the 4 screws holding the mid section together?
Old 04-17-2006, 06:39 PM
ProjectDarkBlack's Avatar
sometimes they have to be broken loose. Just loosen the bolts on both sides so that they are hand tight, clock it how you want it, and then re-tighten
Hybrid_Coupe's Avatar
no...sometimes the turbine housing is really hard to move....you just need to give it a little persuasion to move!
Old 04-17-2006, 07:14 PM
Default Re: (Hybrid_Coupe)
okay will do cuse the compressor side moved easily but the turbine side I SAID GODDAM! that **** didnt move
Old 04-24-2006, 04:25 PM
GaRn's Avatar
Default Re: (BoostedGreddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedGreddy &raquo;</TD></TR><TR><TD CLASS="quote">okay will do cuse the compressor side moved easily but the turbine side I SAID GODDAM! that **** didnt move </TD></TR></TABLE>
Oh yea, forgot about that hehe.. I put on a crappy fitting on the center section water jacket, put the turbine housing in a vice, and beat the crap out of the center section one side at a time along with some liquid wrench in the area and I might have torched it too haha..
but it eventually came out..
Dunc
06-22-2011 10:35 AM
Cloner
09-20-2007 09:17 AM
Dunc
05-23-2006 12:20 PM
sheissrx
03-29-2005 04:16 PM
Clone
11-07-2004 05:57 AM
Quick Reply: Adjusting Turbo Need help please
