Adjusting the fuel pressure with my setup.
Old Jan 17, 2002 | 08:40 AM
boost killz's Avatar
New User
Default Adjusting the fuel pressure with my setup.
Ok setup is greddy @7psi, 255lph in-tank pump, along with the 310cc's, with an aem fpr....
Now with vacuum disconnected should it be set to 42 psi? and do I need to close off the vaccum when making this adjustment?
And with the vacuum connected what should I expect to see?
I think it's my fuel pressure adjustment that has the car running like crap..Thanks guys,
Nick
Old Jan 17, 2002 | 09:56 AM
New User
Default Re: Adjusting the fuel pressure with my setup. (boost killz)
Anyone please... I am getting desperate for a sure answer and the search does not have anything concerning my setup.
Turbo isn't fun when it doesn't work properly..
TIA
Nick
Old Jan 17, 2002 | 10:03 AM
VTC_CiViC's Avatar
Still having problems with it Nick?? I've got the "bible" at home and I could check the stock numbers for you if you want..?
Old Jan 17, 2002 | 10:24 AM
Xerxes's Avatar
New User
are you running lean? I believe you want fuel pressures of around 38 psi at idle, which is 48 psi with the vacuum hose disconnected. Try turning up the pressure to 48 and see if the car runs any better.
EDIT: actually you can just adjust it with the hose connected too.. turn it up to around 38psi with the hose connected and see if that helps
-Xerxes
[Modified by Xerxes, 7:28 PM 1/17/2002]
Old Jan 17, 2002 | 10:55 AM
VTC_CiViC's Avatar
Default Re: Adjusting the fuel pressure with my setup. (Xerxes)
Actually, he's already at 40 with the vaccum line attatched..
Old Jan 17, 2002 | 10:57 AM
New User
Default Re: Adjusting the fuel pressure with my setup. (VTC_CiViC)
Dave I just spoke to Abid and confirmed again... Reason could be cuz simply that blue box POS cant sompensate for the extra volume of fuel from the pump... Ahh I love this ...
Old Jan 17, 2002 | 12:14 PM
downpipe's Avatar
that blue box has become the root of all evil. damn it to hell!
Old Jan 17, 2002 | 01:33 PM
DA666's Avatar
Default Re: Adjusting the fuel pressure with my setup. (downpipe)
take out the intank and do bosch in line fuel pump spliced in after the stock intank, the fuel pressure that builds up between the intank, to inline, to rail is better than the crapo holley 255lph ones......no offense......go to endyn.com for more info...then you'll better understand the difference between fuel pressure, fuel volume......cos it's a heavilied discussed topic in h.t.....other than that do a search.
GsrIntegra789
Jun 4, 2008 04:00 PM
digital sol
Aug 6, 2007 05:10 PM
s1ngle
Apr 14, 2005 12:14 PM
TrboInteg
Oct 26, 2003 06:57 PM
toooslow
Jun 13, 2003 04:06 PM
