Adjustable wastegate??
Old Jun 6, 2006 | 04:50 PM
HCRX311's Avatar
Default Adjustable wastegate??
I have a T3 42/48 turbo off a stock car, 4 bolt DP, and the wastegate is not the type with a nut and rod to screw adjust. It just has a spring in it... I dont know the spring rate though...and I assume a tial spring wont work....
Is there anyway to adjust this...or keep the boost down if the spring is say like 10-11 psi spring. I'm looking to run around 6-8 psi. Here's the best pic of it I got right now....just let me know if anyone, has any clue about these or actually has one. Thanks.
Old Jun 7, 2006 | 02:56 AM
HCRX311's Avatar
Default Re: Adjustable wastegate?? (HCRX311)
bump..
Old Jun 7, 2006 | 04:00 AM
k24em2's Avatar
So there is just a spring behind the flapper door?
Old Jun 7, 2006 | 11:33 AM
HCRX311's Avatar
Default Re: Adjustable wastegate?? (k24em2)
I'll have to get a better picture, but it looks like a tial....its like a bee hive with vacuum line off it, with a big spring in it.
Old Jun 8, 2006 | 11:50 AM
HCRX311's Avatar
anyone?
Old Jun 19, 2006 | 02:35 PM
HCRX311's Avatar
Default Re: (HCRX311)
anyone know?
Old Jun 19, 2006 | 03:31 PM
EK k kay's Avatar
You cannot adjust the psi lower than what the spring is.
Old Jun 20, 2006 | 02:30 PM
HCRX311's Avatar
Default Re: (EK k kay)
Ok I figured that, but is there a way to get a lower psi spring for a stock wastegate if that one is set to high?
Old Jun 29, 2006 | 03:32 AM
HCRX311's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HCRX311 &raquo;</TD></TR><TR><TD CLASS="quote">Ok I figured that, but is there a way to get a lower psi spring for a stock wastegate if that one is set to high?</TD></TR></TABLE>
turbo-crx
Apr 1, 2009 11:42 AM
H-T guy
May 19, 2007 01:08 AM
Bimmerman
May 7, 2005 06:45 PM
b18-c-rx
Feb 22, 2005 06:52 PM
NORCALCVC
Feb 15, 2005 11:57 PM
