ACL race or duraglide bearings
Old 11-06-2009, 08:31 AM
  #26
Turbo-LS's Avatar
Default Re: ACL race or duraglide bearings
yeah .0035 is good but .0040 is quite a bit of ptw for a daily driver and just not nessesary.
Running .0030 currently on my setup but im also runnign srp pistons that have high silicon content and dont have the expansion rate that the cp's and other low silicon content pistons have. Granted there not as strong of a piston but they will still handle plenty of abuse and power
Old 11-06-2009, 08:49 AM
  #27
Bond's Avatar
Originally Posted by Turbo-LS
yeah .0035 is good but .0040 is quite a bit of ptw for a daily driver and just not necessary.
Running .0030 currently on my setup but I'm also running srp pistons that have high silicon content and dont have the expansion rate that the cp's and other low silicon content pistons have. Granted there not as strong of a piston but they will still handle plenty of abuse and power
Agreed 100%
I was just referring to my setup, but all are different. Best to research your piston and make a good decision that suits ur uses and material the best.
Old 11-06-2009, 07:38 PM
  #28
Transpoquick's Avatar
I'm running 10 40 too, Mobil one. No problems...with oil. My motor makes around 300 on nitrous.
Old 11-08-2009, 03:40 PM
  #29
battlecrxT's Avatar
If you get the standard size Acl's can you just pop them in Plastigage and go? And if they are a bit to tight or loose how do you adjust?
Old 11-09-2009, 03:49 PM
  #30
Yes, if you got good parts that are within spec.. The second part is a long explanation, best too figure out if there is a problem then post it. A lot of circumstances could make bearings too tight or loose, and there is many ways too correct it. Are you talking about Con rod or main bearings?, each one would involve a different procedure.
So whats the problem?, are they tight or loose and is it con rod or main bearings?.
Old 11-09-2009, 04:02 PM
  #31
battlecrxT's Avatar
Just wanted the knowledge really how to adjust both. I just ordered a set today so when they get here wed I will find out. Thanx for the answer back man.
Old 11-10-2009, 12:40 PM
  #32
champLSinteg's Avatar
Only once have I had ACLs be a little too tight for my liking and just went with oem. Other than that, I have no issues at all. Just plastigage 3 times if you have too!
adubaz7
10-03-2007 07:49 PM
7rrivera7
01-12-2007 02:49 PM
RapeV-8
11-15-2006 11:01 AM
polymath
17
07-29-2006 03:09 PM
RACEPAK
24
11-09-2005 11:08 AM
Quick Reply: ACL race or duraglide bearings
