Auto Dyno software from BahnTech
Old Jun 20, 2004 | 05:15 AM
JOeS's Avatar
Default Auto Dyno software from BahnTech
Does anyone have experience with Auto Dyno software from Bahntech? It looks great
http://bahntech.com/products/Auto_Dyno/default.asp
Auto Dyno Performance Meter:
BahnTech’s AutoDyno Performance Meter is the first to combine Dynamometer, Performance, and Tuning functions into one unit. AutoDyno is a full-featured dyno graphing up to nine horsepower and torque runs simultaneously. Performance data is also collected including 0-60 Times, ¼ Mile Times, Passing Speeds, Braking Distance, and Acceleration GForce. AutoDyno is also an advanced tuning tool featuring up to four 0-15v data collection channels sampling 100 times a second. These channels can be used to record Wide Band O2, MAF, Throttle Position, MAP, Boost, or other vehicle sensor data.
Your vehicles performance is only as good as the tools used to create it. AutoDyno is a must-have tool for the serious tuner.
Our Auto Dyno product is an entire Vehicle Information System [VIS]. This includes all hardware and software to measure engine horsepower, brake horsepower, collect data, view it in real time, and graph it with advanced post processing data conditioning. The processed data includes Horsepower and Torque at the Flywheel and the Rear Tires. We also measure your 0-60 [and all other 0-x Times], 60', 1/4 Mile, 1/8 Mile, Max Speed, Braking Distance, and Passing Speeds. This data is displayed on your Notebook PC both in real time and after the run.
Auto Dyno can record up to 9 horsepower and torque dynamometer runs and graph them together on one graph. Dynamometer runs can be saved to your hard disk and reloaded later for review. Recorded runs can also be played back in real time or slow motion.
Auto Dyno supports full hands free operation. Auto Dyno can be programmed to start recording data when your throttle is pushed all the way to the floor and record as long as it stays there or for a preset period of time. It can also work like a camcorder with Record, Play, and Pause buttons. The Record button can be set to delay X seconds before recording starts. This gives you time to prepare for the test run.
Auto Dyno has two real time displays: [Automotive Analog and Digital]. These display your current Vehicle Speed, RPM, and up to four 0-15v Inputs. This allows you to monitor other sensors while you drive.
Price $199.99
This also seems like a great deal:
https://honda-tech.com/zerothread?id=881064
Does someone have this?
Modified by JOeS at 1:49 PM 6/22/2004
Modified by JOeS at 1:51 PM 6/22/2004
Modified by JOeS at 1:52 PM 6/22/2004
Old Jun 20, 2004 | 09:01 AM
JOeS's Avatar
Default Re: Auto Dyno software from BahnTech (JOeS)
anyone?
Old Jun 20, 2004 | 02:26 PM
JOeS's Avatar
Noone?
Old Jun 20, 2004 | 03:07 PM
mattcalica's Avatar
wow...i would like to know as well...that thing looks very good.
Old Jun 20, 2004 | 06:13 PM
project's Avatar
Default Re: (mattcalica)
pm tony from import palace technician 419 is his username.
Old Jun 21, 2004 | 12:14 AM
JOeS's Avatar
Default Re: (project)
Tony from Import Palace sells those or does he work with it?
Old Jun 22, 2004 | 04:49 AM
JOeS's Avatar
Default Re: (JOeS)
It only costs $199.99, I might give it a try...
Chris Litten
Feb 5, 2003 07:50 AM
