ACL bearing ??
Old Dec 18, 2003 | 05:06 AM
yellowturbo's Avatar
Default ACL bearing ??
I heard about those bearing ... im rebuilding my whole engine ... do they worth it... I was going to put OEM bearing .... and were I can find them ?? if it is better than OEM Honda
Old Dec 18, 2003 | 05:15 AM
pissedoffsol's Avatar
25 Year Member
Default Re: ACL bearing ?? (yellowturbo)
pm earl. elaskey@***.net
got mine from him
Old Dec 18, 2003 | 05:31 AM
ok but are they really better than OEM ???
Old Dec 18, 2003 | 06:29 AM
ChillOutWayne's Avatar
i heard they are good...their specs match all Honda Greens i guess, but alot of guys never have clearance problems i guess...anyway if u lookin for B-series, have fun, i cant find anyone that has them in stock for my car...i guess its gonna be a couple weeks or so
Old Dec 18, 2003 | 06:46 AM
no it is for a D serie.... I think that I will go with OEM ... less trouble ...
Old Dec 18, 2003 | 06:57 AM
genop's Avatar
Default Re: (yellowturbo)
If you are using aftermarket rods the acl bearings will work fine. The reason you have to get different sized honda bearings is because the specs on the big end of the rod always comes out a little different, with aftermarket rods the specs are USUALLY about the same but you should still plastigauge it to make sure. (assuming you bought a qaulity product) this is how is was explained to me. Hope it helps.
Old Dec 18, 2003 | 07:06 AM
Muckman's Avatar
Moderator in Chief
OEM will be more trouble. ACL is one size fits all. OEM has different colors that represent different thicknesses. The clearance has to be measured and the right size ordered. The prices are about the same. I suppose you could just order the middle size OEM bearings and they would be comparible to the ACLs.
Old Dec 18, 2003 | 07:15 AM
how a bearing could be universal ??? I mean ...how can it replace the good clearance ???
Old Dec 18, 2003 | 07:18 AM
I know that Honda need the good color and all this... my engine builder would use plastiguage to get the good clearance but I find strange to order middle size bearing ???
Old Dec 18, 2003 | 07:51 AM
Ri5e's Avatar
Works fine , PM "Earl"
Old Dec 18, 2003 | 08:23 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowturbo &raquo;</TD></TR><TR><TD CLASS="quote">how a bearing could be universal ??? I mean ...how can it replace the good clearance ??? </TD></TR></TABLE>
Most auto manufacturers only use one bearing size. Honda is one of the few with the color coded bearing system.
4EN[sic]
Jul 24, 2007 12:47 PM
tobe1424
Sep 6, 2006 10:31 PM
Takumi Fujiwara
97
Nov 18, 2005 11:54 AM
GSRCRXsi
14
Jul 11, 2005 07:09 PM
phatrick2332
Aug 31, 2003 09:25 PM
