99-00 civic si ecu code #73
Old Jun 12, 2002 | 09:32 PM
ecko's Avatar
Default 99-00 civic si ecu code #73
need help. trying to get rid of this code. any help will be greatly appreciated. thanx.
MY SET-UP:
2000 civic si with 12,000 miles
greddy td05-18g kit with intercooler.
stock injectors
vortech fmu 12:1 (no blue box)
missing link
airtex inline fuel pump
hks ssbov
ngk spark plugs (like the one's in the drag 3 kit)
Old Jun 12, 2002 | 09:36 PM
Flamenco-T's Avatar
Default Re: 99-00 civic si ecu code #73 (ecko)
73 I think is a misfire code in cilynder 3.
check your plugs..do compression test andl leakdown
Old Jun 12, 2002 | 09:47 PM
ecko's Avatar
anything else...my kit is only a week old. only boosted to 5psi when i was under boost.
Old Jun 12, 2002 | 10:21 PM
inspyral's Avatar
This might sound dumb, but make sure your plugs are gapped correctly(.030), torqued down, and that your plug wires are completely on.
Old Jun 12, 2002 | 10:43 PM
ecko's Avatar
Default Re: 99-00 civic si ecu code #73 (inspyral)
my plugs are gapped at .30 and plugs wires are completely on.
Old Jun 13, 2002 | 05:19 PM
Xerxes's Avatar
New User
might be too rich, causing a misfire... code 73 is a misfire, there's no doubt about that.
i'd do a compression check just to be safe though.
-Xerxes
Old Jun 14, 2002 | 08:14 PM
ecko's Avatar
Default Re: 99-00 civic si ecu code #73 (Xerxes)
Does anyone know what else would be causing the 73 code?(besides being spark plug related?) I've only had the kit on my car for about two weeks. I've only driven it for like 5 days since the install till the 73 code came up. I changed the plugs on monday( to the ngk plugs used in drag gen 3 kits ). 2 days after the code came back up. Since then the car is sitting till i can figure out why the code is coming up. Any help will be greatly appreciated. Can the 73 code be injector related?.......
Old Jun 14, 2002 | 09:46 PM
Arturbo's Avatar
Better than steak
25 Year Member
FMU.. take the fuel return line off of the FMU and put it back on the fuel regulator. Reset the ECU by taking the neg. battery terminal off. Turn the car on and drive around, but DO NOT BOOST. BTW, do you have something other than the stock fuel regulator?
art
Old Jun 15, 2002 | 12:17 AM
Sonny's Avatar
Default Re: 99-00 civic si ecu code #73 (Arturbo)
The Greddy kit uses the FCU aka Blue Box with 310cc injectors instead of an FMU. Unfortunately, the misfire codes and code 13's seem to be common with this particular setup. There was some info on Club Si awhile back about getting in touch with Greddy to help resolve these problems. You might wanna go search for that.
Sonny
Old Jun 15, 2002 | 12:27 AM
thejdmkid's Avatar
Default Re: 99-00 civic si ecu code #73 (Sonny)
i have delt with this first hand, an am still dealing with it on a 99 gsr with greddy. make sure all injectors a properly seated an there is no overlooked gaskets on the fuel rail, also make sure that the fcu is soildered into the ecu an no t-taps. make sure ur not running extra rich. thats about all the hekp i can give yaa....
Old Jun 15, 2002 | 12:31 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: 99-00 civic si ecu code #73 (thejdmkid)
FYI, he isnt using a FCU or the injectors, he is using the FMU and stock injectors.
art
Old Jun 15, 2002 | 12:39 AM
Sonny's Avatar
Good eye, Art. Maybe I should have read the original post, too. Time to go to bed...Zzzz
Sonny
JDMHondaEJ8
Dec 3, 2010 08:55 PM
jpangeles
Oct 13, 2004 06:57 PM
autoEXturbo
Jan 13, 2003 08:44 AM
AutoboTxEK
Apr 3, 2002 09:49 AM
311
Jan 7, 2002 01:53 AM
